Sly1990 "Cmd Post" UPD 07-19-10 - 120V Electricity
Postby sly1990 » Mon Jul 05, 2010 12:23 am
Based on This Thread I tried to make myself a Puck Light,
The casing look is a succes from an old 3/4 test Pine board.
Pretty impressive what some hole saw and some hand sanding can do...
Here's how I did.
Held the whole thing in a Vise.
I began by drilling the circonference with a 4" hole saw. (I kept 1/8" uncut in depth.
Then, I started with the biggest inner hole (2½"). Approx 3/16" depth. --> (To seat the PCB)
Next, I Used the 2" holesaw to an other 3/8" depth. (9/16" Total) --> (To Hold the Lexan). Leaves me approx 3/16" depth available.
Next, the center hole with a 1 3/4" --> (To let the light out...)
*After, You can clean easely the crap between stages with a flat screwdriver.
Finished the 4" hole (I started first) and started sanding...
I used some leftover 3/16" Lexan sheet from an other project and a old piece of Pine laying in my garage...
It looks awesome and its not even finished.....
I Also thought of venting em by doing 6x 1/8" holes on the side and by having a hole on center of PCB. :thumbsup:
I'll Use 2x 1W Led (or 3) per puck. 3.3V @ 0.33A (160* view).
These can turn you blind if you look at em to close within the 160 degree Radius... :lol:
Heres my calculations for 2 Led/Puck (Led in series)
R = (VSource - Volt LED) / Amps LED
R = (12.6V - 6.6V) / 0.33A = 18.18Ω
PRes = (6V * 0.33) = 1.98W
(4x 72Ω 1/2W in parallel.)
Heres my calculations for 3 Led/Puck (Led in series)
R = (12.6V - 9.9V) / 0.33A = 8.18Ω
PRes = (2.7V * 0.33) = 0.891W
(2x 16Ω 1/2W in parallel.)
OR
Connecting 2x (2 Led) Puck Lights in Series to Eliminate the useless Heating and
power eating resistor in the circuit.
EMAX LED = 3.3V x (2 x 2 Led) = 13.6V
In Theory the Puck lights would be near optimal brightness, will have less heat dissipation if
the car alternator is charging and they will have a longer life....
I think it's the best solution but 3 led looks better than a 2 leds puck IMHO...
Will test and post the results...
I have an Idea, but dont have the thing on hand at home to confirm it.
I have access to Old LCD screen. In those, there is some back Reflective papers between the Backlight and the LCD itself. To be simple,
it gives the screen a uniform brightness. (So, you dont see the Blacklithing brigther on top and bottom than in the middle of the screen)
With those, the light wont pass if not within a certain angle. So i could make the led more like a "Cool" lightning... :thinking:
And, we wont see the PCB and the leds at all... :D
I cant wait to test that theory. :twisted:
I started the top Cabinet.
Starting from the top:
On each side goes a 6" Speaker.
On center im undecided if i leave it open of with a big or 2 small doors. (No worry, i can think about this later....)
In the middle, 2 small cabinet. between em goes 2 embeded 3" Can Holder, a 120V (For eventual alarm clock) and 12V Outlets and 2 (or 3) Puck Lights
On the Bottom (Not builded yet), will be 2 big cabinet. strong enough to support us when we will lean back against it to watch TV. I have no Idea yet how I will do it...
Also, I'll need to finish the floor and roof there before going any further with the bottom Cabs.
You can notice one of the future 3" Embeded glass Holder.
At the time to take these photo, only 4 screw were in place to hold all this... (No j/k..) :lol:
On this pic, Everything is holding by my prayer.... :shock:
sly1990
Postby sly1990 » Mon Jul 05, 2010 8:03 pm
Here's an update about the Puck Lights
I took some pic after getting my missing material for my experiment...
View with the lexan only.
Lexan sandwiched with the diffusing material.
Told you that this thing will turn you blind..... :shock:
It's approximately 400,000 mcd each @ 110* View LED.... (I was wrong on the angle in my last post.)
- Some Future PCB (Not etched yet). As Reflector, I'll simply tinplate the PCB.
- Some of the LEDs. (The Sticker says 3.27V 0.310A. Ill revise my calculations)
but it wont make a big difference...
- On the right, The Reflective material. I dont know how to tell it in english, it's
a sort of Light Diffraction control Material. (As explained in my last post...)
I used 2 pieces. One on each side of the Lexan.
Here the 2 Led PCB i made at the speed of light juste for test purpose...
Resistor used : 18Ω 2W
This setup is a NO-NO because of unnecessary heat generated by resistor.....
On the other side, the leds where barely warm. The PCB seems to do a great job at dissipating the heat.
**The next PCB will be Etched and Tinplated (will work as a Natural Reflector...) :R
Not something gross like that..... :lol:
Without a doubt, the 3rd option I mentionned in the last post is the best.
The Resistor produce unecessary heat. (Without mentionning consuming power also for nothing)
sly1990
Postby teardrop_focus » Mon Jul 05, 2010 11:58 pm
Dude, you have some mad skillz!!!
:bowdown:
teardrop_focus
Images: 127
Postby YuGun » Tue Jul 06, 2010 7:33 am
Very nice custom lights,
İ am impressed with it.
YuGun
Postby xddorox » Tue Jul 06, 2010 10:38 pm
Hey Sly, I taught that Crown Vic looked familiar (Can't miss that awesome looking stance). I live in the borough of Ahuntsic as well. I'm planning something along the same lines as yours. You mind if I swing by some time to see your build in person?
Thanks
Gerry :)
xddorox
Postby sly1990 » Wed Jul 07, 2010 11:09 pm
Thanks guys... :thumbsup:
Gerry, Why not..... 8)
What a coincidence that you recognized my car over this forum... :lol:
Your right, I live in Ahuntsic near the 19 Hwy (Papineau st.)
I guess we still live in a small world...
Tu seras le bienvenue... :thumbsup:
Tu vas venir en bicycle? :D
sly1990
Postby xddorox » Sat Jul 10, 2010 5:38 pm
I'm out of town this week but I will definitely swing by on my bike next week. I'll give you a heads up first and we'll hook up then.
Salut :)
xddorox
Postby sly1990 » Sun Jul 18, 2010 11:58 pm
Gerry, Just let me know... BTW, I only work on it on the week-end :D
DAY 15
Today I bought:
3x Laminated Pine 54$
3x Expandable Foam Can 35$
2x 2"x1"x8 Pine 12$
1x 5"x1"x6 Pine 6$
5x 120V Outlet (Black) 12$
2x Masonite 4'x8' 20$
1x Finishing Nails 10$
Total : 169$
Grand Total Yet : 2046$
Here's the Automatic Transfer Switch I made.
When an external 120V AC Source is present (Connected to the 120V 15A Outside Inlet) the relay automaticly feed the 120V Outlet of the TD
while the 25A Intelligent battery charger starts automaticly to do it's job...
:D
Dont mind about the sticker inside the box.... I used an old Timer box.
Will personalise wth my own wiring diagram... :thumbsup:
Here's the Schematic.... 8)
I Forgot to mention that I Fused the Hot Wire... Not the Neutral...
Yellow Wire = Neutral
Red Wire = Hot
Important note : If someone does something like me, Dont forget to always check the source with a polarity/circuit tester (10$ at home depot) before plug it in....
Maybe some idiot did improvised theirselve as electrician and did not respect the Neutral/Hot Wire position. And also to ensure you have a correct ground.
I think i Will add 2 Led to this box...
One Red for the Inverter Power and a Green for the External Power.
So I will always be sure of the power source I rely on.
I decided to replace the White outlets by Black ones.... Will look better with the rest....
sly1990
Postby sly1990 » Mon Jul 19, 2010 12:03 am
All those curves on the floor end gave me a hard time...
Still need doors and 6" speaker...
The black boxes are only for my entertainement while building... :? :lol:
As Said before, The Black Outlets looks real good... :thumbsup:
Unfortunately, on this pic I haven't replaced the TV outlet yet...
... and I also caught the future Solar Panel Wire that was dropping from roof.
:lol:
Im thinking of adding a Voltmeter inside the cabin for the 12V side. Not sure yet if I will use this one... Not precise enough... 0-30V...
External Power Inlet (120V 15A)
I officially finished the roof insulation.
I finished filling everything with expandable foam but I went out of Metal Tape....
Next Weekend I'll be able to close the sandwich with the Masonite Panels and cut the edges to the roof curve...
:twisted:
sly1990
Postby xddorox » Sat Jul 24, 2010 6:55 pm
I had the honor to see the Command Post in the flesh today. Sly my friend you do have Mad Skillz. :thumbsup: Those white LED's are blinding bright too! :?
xddorox
Postby sly1990 » Mon Jul 26, 2010 12:42 am
thx... :thumbsup:
I only worked on my "PuckLight" this week-end.
Global View of the 4x brand new 4" PuckLight I made. (Still unvarnished.)
The top left one is what it should look like when assembled.
The PCB. Peace man! :lol:
The Sandwich. 2 layer of Diffractive material (Top & Bottom) and Lexan (Middle)
Somewhere this week I will build a Dome Light using the same technique.
But with a 6-7" diameter.
sly1990
Postby sly1990 » Sun Aug 01, 2010 5:51 pm
Closed the roof sandwich, removed the exceedin edge of the side panels and I injected
expanding foam to fill any airspace left under masonite.
This thing is really strong. To keep my panel from waving when the foam
was expanding, I've put 4x (40lb) cement block on top + my weight. (~240LB).
I Can now certified that the roof can easely handle +400lb.... :lol:
A look with the TV. Not installed yet. It's just standing on its own. no wall support Bracket yet...
This is my HAM External Antenna Connector (SS plate + UHF Connector) to connect to any other
external field antena (Ex: "Long Wire HF dipole" or a "Yagi")
Also, I plan to install an Antenna Bracket on the roof (Front).
A squared Aluminium Tubing (2" x 1") to drill MMO Antenna mount.
Here what should go onto this bracket.
Antenna for: GPS, Dual-Band (VHF-UHF), HF (10-11M), VHF (APRS dedicated.), UHF (FRS dedicated), Led White strobe light.
BTW This is one good reason why I wanted a Metallic Roof.
I was needing a Ground Plane (to be simple, a Grounded Reflecting Metallic Surface) for my antennas.
With the Rubber Cap. :thumbsup:
The varnished PuckLight. (I soaked them in the Varnish pot...)
They holds by 3 finishing nails drying.
I forgot to make the 3 hole for the SS screw. when they'll dry, i'll drill em and soa it again. :thumbsup:
sly1990
Postby Cliffmeister2000 » Sun Aug 01, 2010 5:55 pm
:thumbsup: :thumbsup: :thumbsup:
Ya know, yore gonna hafta break down and buy a trailer pretty soon!
:D
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby sly1990 » Sun Aug 01, 2010 7:18 pm
Yeah... I expect that pulling this up will be a pain....
Maybe at 6 we could be able to lift it while somebody insert the trailer under...
The construction of the trailer should begin in 1-2 week. Done on week end only... :(
sly1990
