225's Teardrop!!!
Re: 225's Weekender.
Postby campmaster-k » Fri Nov 30, 2012 6:58 pm
Most excellent build. 8)
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby 225 » Thu Dec 06, 2012 2:12 pm
Well, back off to work for a month. Because of my motorcycle rebuild, I haven't done anymore. Hopefully when I get off, I'll be finished with most of it. Only time will tell.
I want to be finished by March. Right now, the deadline is getting tight.
Here are some high res pics I took with my DSLR.
Tongue in/out:
All the cabin stuff that hasn't been used:
Postby capy235 » Thu Dec 06, 2012 8:03 pm
Just looking at you last picture of the frame. I think you might want to look carefully at the placement of the tongue jack. It is so far forward that I am concerned you will damage it when turning and backing. I found out the hard way to leave more clearance.
capy235
Postby RandyG » Thu Dec 06, 2012 9:07 pm
I like your idea of an adjustable tongue, it can give you a lot of choices as far as weight distribution to get your tongue weight just where you want it.
Randy
RandyG
Images: 115
Postby 225 » Fri Dec 07, 2012 2:49 pm
Funny you said something about that. I have been actually thinking about switching it out with one like this:
capy235 wrote:Just looking at you last picture of the frame. I think you might want to look carefully at the placement of the tongue jack. It is so far forward that I am concerned you will damage it when turning and backing. I found out the hard way to leave more clearance.
Thanks. I will have a motorcycle hauler on the rear of the trailer sometimes. Plus with my long bed pickup, it's easier when the trailer is longer when I have to back it up.
RandyG wrote:I like your idea of an adjustable tongue, it can give you a lot of choices as far as weight distribution to get your tongue weight just where you want it.
Postby 225 » Tue Dec 25, 2012 3:32 am
Edit: Build is going to continue.
Re: 225's Teardrop Camper!
Postby 225 » Fri Feb 22, 2013 2:40 pm
Ordered the rest of the parts I needed to start the actual construction of the camper.
Hurricane hinge:
Door:
Epoxy filler:
Ordered these for the hatch.
Now I can start building. The outside will almost be completely sealed once I start. Other than bed liner. Which I will order soon.
Postby Steve 70 » Fri Feb 22, 2013 8:29 pm
Glad to see you are going to go on with the build!! :thumbsup:
Steve 70
Images: 78
Postby RandyG » Sat Feb 23, 2013 12:39 am
Steve 70 wrote:Glad to see you are going to go on with the build!! :thumbsup:
X2
Randy
RandyG
Images: 115
Postby 225 » Mon Feb 25, 2013 2:17 pm
Thanks guys. I am finally buckling down and going to knock it out.
Ordered a PROGRESSIVE DYNAMICS PD40450 AC/DC PANEL 45 AMP RV CONVERTER POWER CENTER today.
Postby aggie79 » Mon Feb 25, 2013 8:54 pm
James,
With the frame built and components purchased it's almost time for sawdust! Keep up the good work.
Take care,
Postby 225 » Mon Feb 25, 2013 11:29 pm
Thanks Tom.
The only thing I can think of that I don't have is wood, the actual wires for wiring, bed liner, window a/c unit, tv mount, and a mattress.
I wanted to have everything I could think of ready that way when I start the construction, I don't have to wait on anything.
Re: 225's Teardrop!!!
Postby 225 » Mon Mar 25, 2013 1:19 am
OK folks, I started this thread on Oct 22 of last year. Been pretty boring right? All you guys have seen is me collecting parts. Last time I was off work, everything came in I ordered. Today, I ordered the bed liner for the bottom, and I am waiting to see how that goes before I buy some for the rest of the camper. I also ordered the hatch seal, but Grant says it's on back order and will take a couple of weeks. No biggie.
I get off work next Tuesday, and will be going out of town for a week for my first trip up to the mountains. Then, I'll be back for some sawdust time. Also I saw a a/c on sale @ HD for $59.00. So I'll be picking that up.
I plan on doing a a/c like 2bits did. And I have been looking over Tom's SB build ( viewtopic.php?f=50&t=26988 ) to see how it's really supposed to be done.
He sets the bar high on how to build a camper.
I will basically have about a week and a half to make it waterproof. That means 80% done. Think I can do it? Maybe a week of 14-16 hour days of camper building, I can knock it out.
I love the weekender, but I think I love the Benroy more. I will make up my mind when I have the sheet of plywood on the saw horses.
Postby aggie79 » Mon Mar 25, 2013 9:49 am
James,
I feel pretty good that you can get your build done and waterproofed in the time that you said. One of the things that made my build take so long is that I mostly worked on it 2-3 hours at a time. When I was able to get a whole day to work on it, I could crank out the work. I'm not much of an organizer, but I found that if I wrote down what I wanted to do ahead of time and the materials that I needed to do them, things seemed to go faster. Also, there are some steps that require glue/epoxy to set, paint to dry, etc. When this happens, have another task ready so you can keep moving along.
Take care,
Postby 225 » Fri Mar 29, 2013 8:59 pm
Well, I went the Benroy profile. I just love it too much. I built the template from paper, so I will have to make adjustments for the door. Also, I welded the fenders and taillight boxes on. I also painted the fenders and over spray on the tires flat black. I am going to box in, in between the rear fender and taillight boxes and fill it with expanded metal.
It's too dark for pics, but I took a break from wiring up the trailer. So tomorrow, I'll start on the floor, and should be finished with it sometime tomorrow.
