Simple Maryland 5 wide build
Re: Simple Maryland 5 wide build
Postby JTROBB » Mon Mar 11, 2013 5:08 pm
Finished up the second side, with the exception of sanding the lat thin coat I applied to fill pin holes created by air bubbles.
Fiberglassed the bottom and that was easy thanks to a tip from a fellow board member (oldragbagger I believe). I used the foam roller to apply the epoxy. The near vertical surface was a real pain and the roller really helped to get the epoxy onto the cloth with out slopping it everywhere. It also was easy due to the fact that is the bottom and I'm not worried about finish.
Tonight I finished sanding the contour on the front and back corners and fiberglass taped them.
Jason
103166103167103170103168103169103171103172103173
JTROBB
Images: 132
Postby GuyllFyre » Mon Mar 11, 2013 6:20 pm
You're making some pretty awesome progress!
The part I hate most is waiting for things to dry.
Things I have for sale on craigslist:
http://albany.craigslist.org/search/?ar ... catAbb=sss
Things I have for sale on eBay:
http://www.ebay.com/sch/merchant/seansmith
GuyllFyre
Postby JTROBB » Sat Mar 16, 2013 6:12 pm
Got the tear in primer today, man do I have a lot of work to do. The primer shows a lot of the minor flaws that I couldn't see with the multicolored Faberge egg look.
Jason
103301103300
JTROBB
Images: 132
Postby Allymooo » Sat Mar 16, 2013 7:14 pm
INSPIRING! Sorry for the caps lock, but it's awesome! :applause: :thumbsup:
Pulling with a 2010 Jeep Wrangler Unlimited Rubicon. Slowly...
Allymooo
Postby JTROBB » Fri Mar 22, 2013 9:04 pm
Got the tear sanded out to 150grit and second coat of primer. Hopefully this weekend I'll be able to sand out to 220grit and spray the third coat of primer.
Jason Robb
103492103491103490103489
JTROBB
Images: 132
Postby KCStudly » Fri Mar 22, 2013 9:46 pm
All of the time you are putting into the finish will surely pay off in a spectacular end result.
You are a body working fool! :thumbsup: :thumbsup: :thumbsup:
(said with great respect from someone who has no patience for body work.)
Postby JTROBB » Sat Mar 23, 2013 9:24 am
I sure hope it turns out well. It almost seems a shame to paint it plain old white. If I don't like the color I can always repaint it.
Jason Robb
JTROBB
Images: 132
Postby harleykamper » Sun Mar 24, 2013 11:14 pm
It's coming very well! It's going to look great with all the elbow grease you're applying. Very nice build. :applause:
Paul & Marilyn Moon
2008 anniversary edition Harley Davidson ElectraGlide Ultra Classic
Kustom KlamShell tent Trailer. (In build now)
The ClamShell Tent Trailer Build Journal viewtopic.php?f=50&t=54531
harleykamper
Images: 206
Postby 225 » Mon Mar 25, 2013 12:44 am
I like it. I understand why you are using fiberglass. I am going the same route, however, I am coating the teardrop with bedliner, soooooo..... I don't have to do any sanding. :D
Postby JTROBB » Tue Mar 26, 2013 4:52 pm
I never thought of bedliner. Should make for a durable surface. Does the bedliner provide any UV protection? Standard epoxy resin for fiberglass will break down from the UV.
Jason
JTROBB
Images: 132
Postby JTROBB » Thu Mar 28, 2013 5:21 pm
Started painting, man am I going to have a lot of sanding to get all of the runs out. At least it is wet sanding so I don't have all that dust everywhere.
Jason
103781
JTROBB
Images: 132
Postby JTROBB » Sat Mar 30, 2013 1:44 pm
Got it painted. Had to do it twice, and I still have a few runs at the bottom front. Haven't decided to just leave the runs or try and wet sand them out?????? The rest of the exterior looks good though.
Jason Robb
103836103835103834103833103832
JTROBB
Images: 132
Postby KCStudly » Sat Mar 30, 2013 10:53 pm
Maybe cut them down with a drip shaver (little device, a block plane, that holds a razor blade just so) and then wet sand?
Available at auto paint suppliers, or so I am told.
Postby Martiangod » Sat Mar 30, 2013 11:08 pm
Lookin like your going to have a rig that will last a looooooooong time.
Finish looks great from where I'm standing :)
A finish many on here would die for, Bravo
Build On!!!! :thumbsup:
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby AlgoDan » Sun Mar 31, 2013 4:54 am
Looking good, one step close to completion.
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
