Sheddie wrote:Rather than bog, what about laminating a strip of wood/ply along the top edge before you put the roof ply on?
dales133 wrote:Sheddie wrote:Rather than bog, what about laminating a strip of wood/ply along the top edge before you put the roof ply on?
Beat ya to it!
KCStudly wrote:Did I miss something? Why not just cut the step in the wall tops deeper?
Sheddie wrote:Hi Laurie, personally I would not go that thin with the spars. You get the most strength across a span with the spars on their edge, not on their side. That is with the bigger measurement vertical not horizontal making them wider won't add much support. I have 42mm x 20mm, the 42mm being the vertical dimension.
If you don't want to drop the ceiling height down, you could look at laminating a strip along the top of the walls to build them up to level with the top of the spars. Unfortunately this may mean a redesign of the hatch.
Keep up the good work it is looking nice.
dales133 wrote:KCStudly wrote:Did I miss something? Why not just cut the step in the wall tops deeper?
That had crossed my mind but id assumed for some reason he couldnt now because it seemed to obvious
Users browsing this forum: Bing [Bot] and 8 guests
