doug hodder wrote:Heikki....think about your camping conditions. Is it going to be used for winter camping? With a body or 2 in it overnight, it will be fine...it's the getting outdoors temps. in the morning that is going to be your problem....get a fire going right away! If it isn't planned to do the really cold camping...just do up the ceiling like Gage mentioned (I'd do that anyway) and go for the solid walls like it was originally constructed.
With decent bedding I've camped down to the lower 20's F with ply construction walls no heat and been fine. If you want lower than that...I'd plan on going with some wall insulation, which will involve either cutting down on the inside space, or cutting into the clearance on the tires, your choice. It kinda comes down to how much room you have to work with side to side and how low do you want to go. Just my opinion.
PS...dogs are great heaters! Doug
Thank You Doug.
Many Thanks again Doug.
