StandUpGuy's TTT (Not-a-RV)
Postby myoung » Sun May 29, 2011 7:19 am
StandUpGuy wrote:Plan view of trailer in "Cargo Mode". Fridge cabinet and small dinette seat removed to allow motorcycle to be loaded inside.
By justoneman at 2011-05-18
Very interesting ideas. How much does the bike weigh? Can you support the load unbalanced a bit to the right side like this?
Mike Young
myoung
Images: 250
Postby StandUpGuy » Sun May 29, 2011 11:49 am
The bike is only a 250cc so it weighs just under 300 lbs. I am more looking for a way to transport the bike locally if needed but I suppose it could be a longer distance traveller with bike too.
StandUpGuy
Images: 52
Postby StandUpGuy » Sun May 29, 2011 11:59 am
I am running into a height calculation error on my part. At some point in the build I bumped up the main ceiling height by 3/4". Now I have done a dry run of wheeling the trailer out of the garage and it just barely clears without the pop top on. My measurments now allow for me to have only 1-1/8" total for top thickness! Now I am not making a very big top. It will only be 48" wide by 64". I really needed that 3/4" So I am left with needing to make a change of plan one way or another.
One option is to attempt to make a 1" thick hatch with a bare minimum lip on the main roof as my rain ledge.
Option two is to take a circular saw and remove material around the entire trailer. The tricky part there is I have the forward ceiling panel glued and screwed in place. There are cross members in the middle that would need to be reduced in height as well.
Option three is to remove height from only the rear portion of the trailer so the pop top when lowered is at the height of the forward existing roof line. This would present me with problems making a rain seal by the hinge area.
Any thoughts?
StandUpGuy
Images: 52
Postby eamarquardt » Sun May 29, 2011 12:33 pm
Deflate the tires to get it in and out of the garage or take em off entirely and use casters to move the trailer in and out.
Everything in life is a compromise.
Gus
eamarquardt
Images: 150
Postby StandUpGuy » Sun May 29, 2011 1:19 pm
eamarquardt wrote:Deflate the tires to get it in and out of the garage or take em off entirely and use casters to move the trailer in and out.
Gus
I think simply deflating the tires would be all that was required, but what a pain in the butt that is. Still I could get a little electric tire inflator and it would have the added benefit of making me have proper tire pressure each time I took it out.
StandUpGuy
Images: 52
Postby StandUpGuy » Sun May 29, 2011 2:56 pm
The prow of the "Not a RV". Maybe a little ugly. Thats OK I was shooting for functional so what would one expect.
By justoneman at 2011-05-29
StandUpGuy
Images: 52
Postby StandUpGuy » Sun May 29, 2011 2:57 pm
Probably when it is all finished and painted it will be more charming. It looks a lot like a horse trailer really.
StandUpGuy
Images: 52
Postby StandUpGuy » Sun May 29, 2011 3:03 pm
Gus
Here was my original plan for the pop top. It was only going to require 1.75" or so as it was. Pretty low profile.
By justoneman at 2011-04-20
StandUpGuy
Images: 52
Postby jkidd6339 » Sun May 29, 2011 6:56 pm
Nice work on your trailer so far. I guess the function would dictate some what the looks of the trailer. Lots of good ideas there. About the height I have the same problem with my garage the builder made it for I think 2 Honda Accords. In order to get a full size truck in there I need to lower the floor and add on 5 feet to the front. That idea has been rollin around in my head for a lot of years now. Good luck on your build.
jkidd6339
Postby StandUpGuy » Sun May 29, 2011 7:45 pm
jkidd6339 wrote:Nice work on your trailer so far. I guess the function would dictate some what the looks of the trailer. Lots of good ideas there. About the height I have the same problem with my garage the builder made it for I think 2 Honda Accords. In order to get a full size truck in there I need to lower the floor and add on 5 feet to the front. That idea has been rollin around in my head for a lot of years now. Good luck on your build.
The way the nose is shaped I am really going to have to fight off the urge to paint a "Flying Tigers" shark mouth on it! :)
StandUpGuy
Images: 52
Postby doug hodder » Sun May 29, 2011 8:13 pm
You never know...it may just settle down a bit once you get it all built/ loaded and a few miles on it, so the 3/4" might not be an issue. I have to either run my 14's down to 5psi for a 1/2" clearance...or swap wheels, which is what I do. I've got some 8"s on a utility trailer that I use. Older Low-liners came with 2 sets of wheels so that they could go into the garage. A hassle...yup, but I have a system, and can swap them out really fast. Nice build! Doug
Postby StandUpGuy » Sun May 29, 2011 8:17 pm
doug hodder wrote:You never know...it may just settle down a bit once you get it all built/ loaded and a few miles on it, so the 3/4" might not be an issue. I have to either run my 14's down to 5psi for a 1/2" clearance...or swap wheels, which is what I do. I've got some 8"s on a utility trailer that I use. Older Low-liners came with 2 sets of wheels so that they could go into the garage. A hassle...yup, but I have a system, and can swap them out really fast. Nice build! Doug
Yes I had not thought of the increased weight as the build goes compressing the springs. Some nice thoughts there thanks. I think I will proceed in the fashion I planned and the worst case scenario is I deflate the tires, or swap them out as you have done. Thanks for that.
StandUpGuy
Images: 52
Postby StandUpGuy » Sun Jun 05, 2011 3:51 pm
Completed framing the pop top and here it is temporarily in place to check fit.
By justoneman at 2011-06-05
StandUpGuy
Images: 52
Postby StandUpGuy » Sun Jun 05, 2011 3:52 pm
Constructed walls for bathroom and installed them.
StandUpGuy
Images: 52
Postby StandUpGuy » Sun Jun 05, 2011 3:53 pm
View from the floor inside looking at the pop top and the new bathroom walls in place.
StandUpGuy
Images: 52
