Lady Bug Winter Warrior - finally campable!
Postby starleen2 » Fri Apr 24, 2009 2:05 pm
Just straightening out some sides (the board is just temporary until the sides are adjusted even with each other
152159
Flooring installed
152160
152161
152162
Air conditioner shelf and cutout
152163
152164
All trimmed out
152165
Wood Rope trim
152161
Now on to installing the Queen sized bed - After that, the Hatch :twisted:
starleen2
5th Teardrop Club
Postby planovet » Fri Apr 24, 2009 2:41 pm
Looks great! :applause:
ImageMark (& Cindi)
planovet
The Cat Man
Postby Cliffmeister2000 » Fri Apr 24, 2009 2:52 pm
Very nice work! It must be sweet to be able to work on it so open like that! :applause:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby starleen2 » Sat Apr 25, 2009 8:13 pm
Decided to make some curtains today (along with other stuff). I had some material left from an upholstery job I did some time back. Mrs Starleen determined that this was fitting enough for the camper so let the sewing begin
152166
Rogaine anyone??
152167
152168
Made a matching set – but you’ll have to wait until more of the build is completed to see em’ installed – got to get those windows in first! Also completed the bed platform and installed aluminum flashing in the wheel wells – Will post some pictures at a later time – to tired from all the days activities. But the check list is getting shorter
starleen2
5th Teardrop Club
Postby starleen2 » Wed Apr 29, 2009 9:39 pm
Geez- I hope my neighbors don’t think I’m running a meth Lab – I’ve started the resin coating process on the lower half. I’m using 5 mm luan so I want it sealed pretty well. My desire is to only have some aluminum trim on the lower panels and around the wheel wells. I have fiberglassed the seams and the edges and now comes the fun – Sanding, sanding, sanding – I came in today covered in fiberglass dust. But its those small details that pay off in the end ;)
starleen2
5th Teardrop Club
Postby rmclarke » Thu Apr 30, 2009 7:05 pm
Great job, I'm enjoying watching this come together.....you're moving right along :thumbsup:
The Winter Warrior design is very cool; it's one I would like to do myself someday......(I hope the wife doesn't read this * * * looks furtively over his shoulder * * *)
Do you have any pics of your fiberglassing? (I've been considering this on my trailer.....mebbe)
Richard
rmclarke
Images: 231
Postby starleen2 » Thu Apr 30, 2009 8:19 pm
rmclarke wrote:Great job, I'm enjoying watching this come together.....you're moving right along :thumbsup:
Richard
Hope to have some soon - Still apply the resin and fiberglassing some seams, and sanding - this rainy weather we're having isn't helping with the curing time either
starleen2
5th Teardrop Club
Postby starleen2 » Fri May 01, 2009 9:40 am
More pictures for you guys - Applying resin to the back
152169
Sanding on the sides – the vertical strips are fiberglassesd seams. The front radius has a strip of fiberglass to seal the edges
152171
Front fillets and seams
152170
Wheel wells finished
152172
starleen2
5th Teardrop Club
Postby Cliffmeister2000 » Fri May 01, 2009 12:46 pm
[quote="starleen2"]
152172
Those wheel wells look ready for a beefy set of mud and snow tires! :thumbsup:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby rmclarke » Fri May 01, 2009 7:11 pm
Scott,
Maybe I missed it earlier in the thread but, what kind of paint/finish are you considering?..........not trying to rush you or anything :whistle:
Richard
rmclarke
Images: 231
Postby starleen2 » Fri May 01, 2009 9:39 pm
rmclarke wrote:Scott,
Richard
This is the paint scheme
Paint will be what I've used before in the three previous builds - An oil based exterior enamel - I'm coating the shell in resin to reduce the chances of plywood "checking" plus I don't want any seams showing or cracking - heck of a way of waterproofing the seams. If moisture can get past them seams - we'll call it houdini!
starleen2
5th Teardrop Club
Postby planovet » Fri May 01, 2009 9:42 pm
Sweet! :applause:
ImageMark (& Cindi)
planovet
The Cat Man
Postby starleen2 » Sat May 02, 2009 2:18 am
Air conditioner installation. The Ac unit slides into place and is secured by two wing nuts. When not in use (winter time camping), the AC can be removed and a hatch plate covers the hole
152173
152177
Installed the windows after the first application of resin. This time I went with the flush mount (after using a home style on the previous three.
152176
152175
Sanding – as you can see, I’m trying to get a good flush fit on the edges with a gentle rounding of the edges. All of the Glass work is done so there should n’t be any seams
152174
152175
Dang - thats a lot of Dust!
starleen2
5th Teardrop Club
Postby Catoosa Grani » Sat May 02, 2009 9:44 pm
That is looking great! You do such nice work. Looking forward to the final unveiling.
Grani
Catoosa Grani
Images: 86
Postby starleen2 » Mon May 04, 2009 8:38 pm
More sanding – Did get a guide coat on to show the spots that need some attention – with the first coat on you can see the compound bow in the front. I’ll give it some drying time and then back to sanding :cry:
152178
I'm getting closer to the Hatch - the whole build hinges on it :lol:
starleen2
5th Teardrop Club
