Well, it has been some time since my last update, probably something like a year. Life intervened in the teardrop build, both personal and professional. The trailer has been sitting under the tent, though, and waiting to be finished. Here's a brief recap of progress since my last post, which was scant, but we're back at it with a vengeance now.
When I last posted a progress report, Kathy and I had just gotten the aluminum outer skins attached. I trimmed them flush with the trailer edges and added aluminum angle to hold everything together and keep the seams dry. All the aluminum angle is caulked with Vulchem caulk, which is nasty sticky stuff to work with but it seals like the dickens. This is the top side trim going on:
By the way, these pics are still from late summer 2012.
Bottom front near the tongue:
Starting to frame the door openings:
We have since fitted a linoleum floor. We added a Fan-tastic vent fan:
We installed and wired the LED reading lights:
One of the several around-the-house projects that interrupted the trailer build. Kathy did most of the knee work on this, thankfully:
That pile is the total waste from this two room floor installation. Needless to say, the last few pieces were like fitting a jigsaw puzzle together. We cut it pretty close, as there were no other boxes of this pattern anywhere locally at the time:
I know, I know-- nothing to do with teardrop trailer building, but it's been a YEAR since my last update. Indulge me a little. Oh, and I made new friends while working on the trailer in the backyard:
OK, back to the trailer build. Here's where the
cautionary tale begins. I had to build the galley hatch THREE TIMES.
In fact, as I write this, the third hatch is not yet completed-- but I'm getting ahead of myself. Here is the problem. I've roughly followed the Kuffel Creek plans for this teardrop, but only roughly. I pretty much abandoned them all together in the galley. That was my first mistake. Note the clearance-- or lack of it-- between the galley furniture and the edge of the curved trailer side:
Pretty tight, huh? Well, it's so tight that the side ribs spec'ed by Kuffel Creek would not fit-- for that matter, I had trouble with the transverse spars, too. They were so wide that the interior skin contacted the galley furniture in several places, making some painful and time consuming adjustments necessary. Here's the hatch-- the first one-- underway, showing one of those necessary adjustments, the notches in the side ribs:
The hatch fits, however, with those notches to clear the furniture inside. So at this point I was pretty happy and not at all concerned:
I skinned the inside with 1/8" Baltic birch ply and the outside with 1/4", and used some offcuts to patch together the outer skin in order to save materials:
By the way, here's a big shout out to Grant Whipp who sold me that 0.040 aluminum offcut for the galley hatch, thus saving me a mult-hundred dollar shipping cost! Yay Grant!
Here is where it all went to hell. Although you can't see it well in this pic, the hatch no longer fits the galley opening. You can sort of see that along the bottom edge, which used to fit nicely but now sticks out a couple inches. The overall curve no longer matches the galley sides, either.
In retrospect it's obvious what happened-- the outer 1/4" ply skin caused considerable spring back. Unfortunately, as obvious as that is now, I didn't understand it at the time and assumed that I'd just screwed up the hatch layout, despite having built the interior ribbing and spars in place and having confirmed the fit half a dozen times myself. Undoubtedly the notches I cut in the side ribs only exacerbated the problem, acting as hinges when the 1/4 in. outer skin sprung back. I just about cried, but there really wasn't any choice. I had to build the galley hatch again.
This required some comforting. You didn't think you could go on the internet without seeing pictures of cats, did you?
In midwinter I started work on the second galley hatch. Since I had the experience of the first hatch interfering with the galley furniture, I built the second hatch thinner, cutting the crosswise spars down from 1.75 inches wide to 1.25. I also cut the side ribs thinner, making them fit into that narrow space allowed by the galley furnishings:
Since it was winter, and the rainy season in northern California, I did most of the work indoors, on top of that brand new floor that the better half wanted to enjoy. This did not win me any attaboys.
If you'll permit me to digress just a little-- we took spring break 2013 off and went to the Mojave, where we camped in the Cadiz Wilderness, one of my favorites. Just imagine the teardrop trailer here instead of the camp:
When we returned, I finished the second hatch. Unfortunately it was constructed similarly to the first, using the Kuffel Creek directions, but only thinner and weaker so I wouldn't need the notches cut into the side ribs:
It's leaning against the fence in the pic above, rather than sitting on the teardrop trailer, because like the first hatch, it didn't fit. At first I was really, really perplexed, because I KNEW that hatch was built to fit properly. That is when I figured out about the spring back. Dammit, I have to build a THIRD hatch!
This time I redesigned the interior ribbing for way more strength. Here we go, beginning in late May 2013:
It still fits. The wiring runs through a chase at the bottom so that I didn't have to cut holes in any of the vertical ribs:
The galley still cleans up nice:
We installed a new electrical system in the shop:
By this time I can build the interior with my eyes closed-- it's the third time! The cross rib trim is clear heart redwood:
I used one layer of 1/8" baltic birch ply on the outer skin, then fitted it. With all the internal ribbing, the thinner skin is plenty rigid, although perhaps a little less puncture resistant. Yesterday, June 30, we checked the fit with the exterior skin on and lo and behold, it fits! O happy day!
Rather than laminate another 1/8" skin outside the first, I'm considering simply laminating strips of 1/8" ply along the outside edges to strengthen them, and simply leaving the rest of the hatch with 1/8" skin. It's lighter, and the whole thing gets covered with 0.040 aluminum. I'll seal the wood with CPES before putting the aluminum on, so I think that will be plenty strong. And it FITS!
We've also been working on the cabin doors. The blue tape in the first pic is to mask the CPES, since I've read that Titebond III doesn't adhere well to epoxy.
The windows are not actually installed yet, just press fit into place in these last two pics:
So that's where we stand now. That last pics of the hatch and the cabin door were taken yesterday. It was a good day.
Which brings me to my last info for this update. Kathy and I had previously scheduled a road trip at the end of July and early August-- she has grandkids to visit and I have to do some insect collecting (I'm a university entomologist in my day job). The departure date, dictated by her vacation schedule, is July 20. Today is July 1.
You know where this is going, right?
The 20 Day Challenge!I'm trying to get the teardrop road worthy in 20 days. To make things even more difficult, I have a couple of meetings in Sacramento during the next couple of weeks, so I'll effectively have something closer to 17 days.
Sawdust is flying.
--Mike C.
If it isn't broke, perhaps a more expensive tool is required to break it....
