Yes that Citroen is a strange beast indeed. I've already started lurking on Citroen websites and I'm learning about the great hydr fluid controversy. I love my Soob and it will always be my primary TV. I'll use the Citroen as well but for now, it will be a hobby car to tinker with.
I'm socked in by the weather but everyday, I try to do a little something to keep my build momentum going. So today, I experimented with bending plexiglass. The front corner windows of the AtomicVistaLuxuryLiner have a similar shape to another wonderfully inappropriately named rolling contradiction: the Spartan Royal Mansion. What a great name. I wish I would have thought of it. But I've never bent plexiglass before so I thought I'd experiment a little. I had a used scrap of plexiglass and it didn't have the protective paper on it. Here is my bending set up:
- avll22.jpg (98.22 KiB) Viewed 1059 times
The welding magnet is about 10 inches from the pipe mandrel which is a 2 IN DIA piece of galvi fence tubing. The idea here is to heat the area over the mandrel until the plexi yields. The weight of the magnet will then pull the plexi down (thru gravity) around the mandrel. You have to be careful heating plexi, too much heat in one spot and it will start to discolor. I used a Wagner paint stripper heat gun for my heat source. It worked well but the big surprise was that the radius of the plexi bend did not conform to the radius of the mandrel. The mandrel has a radius of 2in/2=1IN. It's hard to see in this pix but the radius of the plexi is much tighter. A 3/4 IN DIA broom handle fits it nicely so I'll guess that the plexi took a radius of about 1/2 X 3/4 or about 3/8s IN. I think this has more to do with heat distribution than anything. I suspect that if I put my mandrel in an oven and got it up to 200 degrees or so and then hit the whole area with the heat gun, the plexi would be more likely to conform to whatever mandrel that I chose to use:
- avll21.jpg (100.55 KiB) Viewed 1059 times
If you look carefully at the far right corner of the bend, you can see what happens if you hold heat in one place too long. The surface of the plexi bubbles microscopic bubbles and it looks like an area of white spray paint. If I still had the brown protective paper on the plexi, this probably wouldn't have happened. Still, not bad for a first attempt. When it comes to bending my windows, I'm going to build a jig so that I get my geometry right. Until then, I'll probably experiment a little more. Bend discoloration below:
[img]
[/img]
