Ok here we go...PMF!
Re: Ok here we go...PMF!
Postby TheOtherSean » Thu Mar 17, 2016 9:45 pm
Your fenders look very slick. Nice job.
TheOtherSean
Images: 111
Postby dales133 » Thu Mar 17, 2016 10:01 pm
Thanks joe.
Glad ive held your interest and thanks for the tip.
dales133
Postby dales133 » Thu Mar 17, 2016 10:05 pm
Thanks sean.
Half the width is covered when its completed witch is a bit of a shame but they still should look pretty sharp.
Was a bit of a worry cutting them to lengh as they wernt that cheap and had to drive 4 hours to get them
dales133
Postby Atomic77 » Thu Mar 17, 2016 11:25 pm
dales133 wrote:Cheers micheal .
How long til you get a chance to attack the astroliner again?
Not sure. So much going on right now. :( Glad you're back at it though.
Here's my tip on brush painting... Don't do it. ;)
Michael
"The Strength is in the Sum of the Parts..."
The Astroliner
Follow The Astroliner Blog Here!
Check out our YouTube video
Atomic77
Images: 309
Postby dales133 » Thu Mar 17, 2016 11:39 pm
Lol thought youd say that.
Got my fuel tank sender unit im using for my water tank the otherday and just installed it
dales133
Postby dales133 » Fri Mar 18, 2016 5:19 am
Set up the brake cables today as i suspected id need to weld on some half chainlink guides for them to keep them as high and out of the way as possible.
Im looking at putting a winder for my spare up underneath so the brake cables will run down the drawbar 2 guides aside.
It isnt a big deal as its only realy lifting the cables not so much changing where they naturaly want to sit.
One more thing i did was add some 6mm shackles to the brake caliper conection points so iff need be i had an easy way to disconect the brakes
dales133
Postby KCStudly » Fri Mar 18, 2016 7:39 am
That level sensor appears to be a quality piece! Doing good work there. :thumbsup:
Postby Vedette » Fri Mar 18, 2016 10:14 am
KCStudly wrote:That level sensor appears to be a quality piece! Doing good work there. :thumbsup:
Yes, that is the coolest fuel sender I have ever seen.
What brand is it?
And, Michael.......that was the best quote I have read here on the forum in a long time. :lol:
I will use it today at lunch with my car buddies!!! ;)
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
What brand is it?
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby dales133 » Fri Mar 18, 2016 11:24 am
Ill have to get back to you with a brand brian but i got it on ebay and they make them in a heap of different lenghs from about 150mm all the way up to about half a meter.
They sell alot of automotive gear and it all seems to be well made.
Came with rubber gasket and mounting hardware ect to.
I think i paid about 36 sheckles for it
dales133
Postby dales133 » Fri Mar 18, 2016 11:50 am
KUS is the brand brian.
Heres an ebay link.
http://m.ebay.com.au/itm/221701477140
30 bucks incl shipping it was.
The have differnt ohm senders to this one is 240 - 33 ...
dales133
Postby dales133 » Fri Mar 18, 2016 8:29 pm
In between the rain im getting a bit done.
Brake cable guides welded on and cable finished off, fitted the gaurd again so i can take measurements to cut the other one down and weld the brackets on.
What do you think of the gaurd lenth?
The front could posibly be shorter...
dales133
Postby KCStudly » Fri Mar 18, 2016 11:34 pm
They look a treat.
Postby dales133 » Fri Mar 18, 2016 11:47 pm
Thanks KC, im going to wet sand them again because i want them perfect but they certainly are coming up how id hoped
dales133
Postby dales133 » Sun Mar 20, 2016 5:54 am
Got the other gaurd mounted up today and made up and welded on the brackets then marked it for cut lenth.
I cleaned up the alko stabiliser brackets that i cut off my mistake....
Ive relocated them and im much happier with thier location,looks tidier and more practical.
Refitted the water tank to make sure the stabalisers clear it and the pipework witch it looks like it will with a close shave.
Realy wish i didnt have to strip it down and flip it as ive done it a few times but i think it will save me time and agro inc the end
dales133
