by mikeschn » Fri Jan 22, 2010 2:07 am
Well John,
Glad all the information helped. Would like to see the progress on your build.
Camping in -20 degrees C, or -4 degrees F is definitely cold. Did you ever tent camp in weather that cold?
What's your plan for heat in the trailer when you are hooked up to 110? And when you are not?
You know you'll want to leave the window cracked open, even in that cold weather to avoid asphyxiation.
