My First Build
My First Build
Postby MikeyLikesIt » Sun Mar 18, 2012 3:20 pm
Here's my progress so far.
I started with an old Rockwood Popup.
Stripped it down.
And started modifications.
Here is how it looks after changing the width to 5'. Adding a spacer between the frame and axle to raise it a few inches. And a fresh coat of paint.
Packed up and ready to go home.
I am getting ready to build the floor. It will be a 1"x2", plywood sandwich with 1 1/2" insulation. Right now the tires set level with the top of the frame. I will most likey swap the 8" wheels/tires for 12" ones. Which would bring the tire about 2" above the frame. I think the fenders will have to be integrated into the wall since they sit a litte on the inside of the frame.
How much clearance do ya'll think I will need for the fenders? The torsion axel seems to be at a low angle with only about an inch or so to go before it would become horizontal. Do these things go past horizontal?
Thanks for looking,
Mikey
MikeyLikesIt
Re: My First Build
Postby WhitneyK » Tue Mar 20, 2012 10:28 pm
Hey fellow Hoosier, looks like you're off to a good start Mikey. What style are you building?
Don't have any experience with the torsion axle as far as expected maximum travel. Do they seem stiff or soft? I allowed 3" from tire to fender, 1. that's the max travel of the axle to frame, and 2. it looked pretty good there. 8)
I agree, the 12" tires would be a better choice too. Good luck with your build
Whitney & Tracie
Crothersville, IN
We never really grow up, we only learn how to act in public.
Do not confuse what you hear with what I mean.
My build: http://www.tnttt.com/viewtopic.php?t=41955
160061-------------------------------101114
States we've drug our
li'l camper through. (44 States + Vancouver Island and over 45,000 miles so far)
WhitneyK
Images: 412
Re: My First Build
Postby MikeyLikesIt » Wed Mar 21, 2012 7:48 am
My original plan was to do something similar to the modernaire. BUT, plans have changed and this project is on hold while I restore a 1960 BeeLine canned ham type camper that I got yesterday.
MikeyLikesIt
Re: My First Build
Postby WhitneyK » Wed Mar 21, 2012 3:21 pm
Good deal on the restoration project, should be for some good, uh,... "experience". ;)
Be sure to post pics of your progress of the restore.
Whitney & Tracie
Crothersville, IN
WhitneyK
Images: 412
