Forrest747 wrote:good luck and remember if you build it where you cant tear down a wall you will only be camping indoors.
Thanks for the reminderDefinetly just doing the individual pieces under cover, then will assemble outside!
looks like a good start. When posting pictures hit gallery and when the pics pop up hit inset image. then we can see them.
What part of SD are you in. My wife worked there a few years just not sure what hospital.
We are in Serra Mesa, near Qualcom stadium and Mission Valley. My wife is actually a nurse at Scripps Green Hospital in La Jolla...
Are you planning one or two doors in the sleeping area.
pohukai wrote:Cutting the luan spline with a circular saw to splice the plywood was difficult for me as well; even with the straight edge. I tried the jig saw with similar results UNTIL I turned off the orbiting feature AND used a blade with 21 TPI. Now, all my jig saw cuts are beautiful. That blade works wonders with cutting lexan nicely as well without any chipping.
aggie79 wrote:Very nice! At your pace, you'll be ahead of your ambitious build schedule. (It took me about 6 months to get to the same point in my build as you are with 3 days of work.)
As you said, cutting 1/8" ply can leave ragged edges. A fine-tooth blade will help eliminate the tear out on the bottom side of the ply. For the top side, you might consider applying masking tape along your cut line and/or scoring the cut line with a utility knife. (I do both.)
For clearance around the bolt heads, set your floor in place. Using a block of wood on top of the floor at a bolt head "whack" each location a few times with a hammer to make an imprint of the bolt head. Flip the floor over and drill relief holes with a spade or forstner bit to the depth you need for clearance.
