San Diego 5 x 8+ build
Postby adventurelad » Mon Jul 16, 2012 2:31 pm
After a rather feverish 1 week design cycle, the build of my new teardrop has begun! The rather ambitious goal is to have a basic usable product in about a month and a half :frightened: But you know, without a deadline, these things could drag on forever. A few :pictures: of the design (in Autocad) as it stood at the begining of the build...once I figure out how to get pictures from my gallery into a post... :?
95126
95127
95128
95129
adventurelad
Building day #1 pics
Postby adventurelad » Mon Jul 16, 2012 2:44 pm
Hopefully this linking works so that you can see the comments with the pictures...
95357
95358
95359
95360
95361
95362
95363
95364
95365
95366
95367
95368
95369
A productive first day :D ...half of the day spent shopping for raw materials, and the other half building. Curious to know how others cut their 1/8 plywood? On day two I used a jig saw which was better, but still a bit ratty on the cut edge... :(
Still can't see the comments from the gallery...anyone know how to properly link the two? :? Thanks! :)
adventurelad
Re: San Diego 5 x 8+ build
Postby adventurelad » Mon Jul 16, 2012 3:03 pm
A short day on Sunday...had other plans. But the floor is now structurally complete, ready for a little sanding, primer, mastic and linoleum.
95374
95373
95372
95371
95370
(Thanks, Forest, for the tip on the pics :D )
adventurelad
Postby Forrest747 » Mon Jul 16, 2012 4:17 pm
good luck and remember if you build it where you cant tear down a wall you will only be camping indoors.
looks like a good start. When posting pictures hit gallery and when the pics pop up hit inset image. then we can see them.
What part of SD are you in. My wife worked there a few years just not sure what hospital.
Are you planning one or two doors in the sleeping area.
Forrest747
Cowbell Donating Member
Images: 447
Postby adventurelad » Mon Jul 16, 2012 6:53 pm
Forrest747 wrote:good luck and remember if you build it where you cant tear down a wall you will only be camping indoors.
Thanks for the reminder :) Definetly just doing the individual pieces under cover, then will assemble outside!
We are in Serra Mesa, near Qualcom stadium and Mission Valley. My wife is actually a nurse at Scripps Green Hospital in La Jolla...
Two doors...don't want to climb over each other for any late night exits! :lol:
adventurelad
Postby pohukai » Mon Jul 16, 2012 7:04 pm
Cutting the luan spline with a circular saw to splice the plywood was difficult for me as well; even with the straight edge. I tried the jig saw with similar results UNTIL I turned off the orbiting feature AND used a blade with 21 TPI. Now, all my jig saw cuts are beautiful. That blade works wonders with cutting lexan nicely as well without any chipping.
pohukai
Images: 9
Postby adventurelad » Tue Jul 17, 2012 9:48 am
pohukai wrote:Cutting the luan spline with a circular saw to splice the plywood was difficult for me as well; even with the straight edge. I tried the jig saw with similar results UNTIL I turned off the orbiting feature AND used a blade with 21 TPI. Now, all my jig saw cuts are beautiful. That blade works wonders with cutting lexan nicely as well without any chipping.
Thanks Jim! :) I also grabbed a metal cutting blade (more teeth, not sure what the exact tpi was), but maybe it is the orbital motion that is the trick. I'll give that a try for the next joins...
adventurelad
Floor primer-ed
Postby adventurelad » Tue Jul 17, 2012 9:54 am
I managed to find an hour last night to finish sand the edges of my floor and apply primer...
95424
Trailer arrives today! :D :D :D
adventurelad
Trailer - NT 5 x 8
Postby adventurelad » Wed Jul 18, 2012 9:59 am
The trailer arrived yesterday! :) Northern Tool 5 x 8, arrived by Yellow Truck in fairly good condition (considering some of the other horror stories I had read here). A few minor scratches, but nothing major.
A few :pictures: of how it arrived, and the specs on the box for reference:
Specifications on the box
95477
Box #1
95478
Box #2
95479
Immediately started assembling (of course)...here is 1 1/2 hours into it (time to stop for dinner :) )
95480
And after 3 1/2 hours (bed time :goodnight: ), the full trailer is assembled except electrical, license plate holder, etc.
95481
Two issues to be worked around with this trailer design will be the protruding bolt heads on the top surface of the deck, and the mounting of the fenders on the side :o
95482
Adventurelad...
adventurelad
Postby aggie79 » Wed Jul 18, 2012 11:04 am
Very nice! At your pace, you'll be ahead of your ambitious build schedule. (It took me about 6 months to get to the same point in my build as you are with 3 days of work.)
As you said, cutting 1/8" ply can leave ragged edges. A fine-tooth blade will help eliminate the tear out on the bottom side of the ply. For the top side, you might consider applying masking tape along your cut line and/or scoring the cut line with a utility knife. (I do both.)
For clearance around the bolt heads, set your floor in place. Using a block of wood on top of the floor at a bolt head "whack" each location a few times with a hammer to make an imprint of the bolt head. Flip the floor over and drill relief holes with a spade or forstner bit to the depth you need for clearance.
Postby Forrest747 » Wed Jul 18, 2012 12:21 pm
And after 3 1/2 hours (bed time ), the full trailer is assembled except electrical, license plate holder, etc.
There is no rest for teh teardropper. Sleep is for whimps.
Forrest747
Images: 447
Postby adventurelad » Wed Jul 18, 2012 1:40 pm
aggie79 wrote:Very nice! At your pace, you'll be ahead of your ambitious build schedule. (It took me about 6 months to get to the same point in my build as you are with 3 days of work.)
Tom, thanks for the advice! The whack-a-mole method sounds much easier than measuring! :thumbsup:
adventurelad
Galley revision
Postby adventurelad » Thu Jul 19, 2012 10:11 am
No building work last night :( However, after assembling our trailer we discoved that it is taller than we accounted for in the original design :shock: So, back to the drawing board on the galley arrangement as the counter height had to drop in order to make it more user friendly. Here is the new arrangement, going with a non-standard propane tank (4 lbs) in order to fit everything in...we usually burn two 1 lb 'green bottles' in a week of camping, so 4 lbs should be plenty. I am a little concerned about the clearance under the cooker, but don't have a depth for it, so just estimating at the moment :NC May still need to bump it up another inch or so...
95579
Adventurelad
adventurelad
Postby Forrest747 » Thu Jul 19, 2012 12:01 pm
I have only taken my trailer out twice so far, and had a great time with it. I did find the trailer feels and interacts alot different in teh wild than it does in the garage. i found the galley in the garage is about the right height but out in the wild it was a little too high on one trip and on the other it was low. darn ground why cant you be flat like in the garage. in fact i had to crank the tongue almost to its lower limit to level the trailer. up an inch or two really not a big deal. how high was your orginal plan?
As a rookie engioneer an older one said just because it looks good on paper doesnt mean it will work.
92380
Forrest747
Images: 447
Postby adventurelad » Thu Jul 19, 2012 5:07 pm
Forrest747 wrote:how high was your orginal plan?
92380
I had read somewhere that the deck of one of the trailers was 15 inches from the ground, so I was using that, so a 4+ inch change :o :shock:
Adding to your observation, just because it looks that way on paper doesn't mean it will be built that way! :D
adventurelad
