New WV build
New WV build
Postby Yakangler » Wed Sep 26, 2012 9:57 pm
WV native here with a stab at a TD build. I got started a little late in the year and space, build conditions, time, and budget are limited... But my reasonable goal is to get at least framed up and working on the interior by the really cold months. Camping by spring!!!!
I've decided on a "weekender" design (modified somehow) after looking at many designs. Simplicity and cost efficiency are the name of the game here. It'll be $10 here and $20 there until we're completed.
No plans, other than the vast supply of ideas on this forum... Sketched up my design and have a 4x8 salvage utility trailer at my disposal (as below)
FIrst 3 weeks of work consisted of stripping the trailer of flooring (steel mesh), grinding some rust, and spraypaint (industrial strength Rustoleum). Then to the 2x frame and 5/8" floor, followed by coating bottom of floor with roofing adhesive.
Total dimensions will be 5x9. Wish me luck...I'm a nurse, not an engineer or fabricator of any type!! :thinking:
John 3:16
Yakangler
Re: New WV build
Postby down under tech » Wed Sep 26, 2012 10:11 pm
Hello and welcome to the madness. That trailer frame looks like it will work nicely. What size is it and do you have any idea of the style TD you are going to build? My Mom is from WV.
Good luck on your build!!! :thumbsup:
Johnny D.
"The Silver Nugget" Build
down under tech
Images: 571
Re: New WV build
Postby KCStudly » Fri Sep 28, 2012 2:59 pm
Your work looks nice and tidy, good attention to detail. :thumbsup:
You'll do just fine. Now, Get 'er done!
Re: New WV build
Postby les45 » Fri Sep 28, 2012 6:05 pm
Welcome from a transplanted Mountaineer from Huntington (actually Thundering Herd class of 68). I'm about to finish a weekender after about six months. Check out my journal and feel free to "borrow" any ideas that you think will work for you. The TNTTT Forum is a great place for advice and info as you build. Don't be bashful about asking as there is always someone somewhere on the forum to answer just about any question you can throw at them.
les45
Images: 605
Re: New WV build
Postby Yakangler » Tue Oct 16, 2012 7:25 pm
Floor bolted to frame with eight 5" bolts and flat/lock washer combination...
Then screwed walls to floor with 2 1/2" deck screws about 4" apart...
Walls and roof framed with 2x3's... Kregged in the roof supports on about 16" centers.
A look at the profile (taken on incline) and detail of the kreg job...
Question is this: Is the framing substantial enough? Plan on 1/4 or 3/8 plywood for roof and walls.
Advice appreciated.
John 3:16
Yakangler
Re: New WV build
Postby Junkboy999 » Tue Oct 30, 2012 5:03 am
Yakangler
Hey I have not built a weekender yet, but from what I seen that framing should be fine. You might just
need some Horizontal bracing above and below where you doors will be.
Junkboy999
Images: 52
Re: New WV build
Postby John T. Hodgen » Sun Feb 24, 2013 8:28 am
Hey Yakangler,
To bad you couldn't have came to the Fall Foliage Gathering in Summersville. We had 25 trailers that you could get Ideas from. :thumbsup: You are doing great on your build :applause: Pencil in the weekend after Bridge Day in Oct this yr for our 4th Gathering. More info will be under the TearJerker's chapter section in the Mountaineers of Wv. Chapter. Any ???'s you can pm me here or on TJ's. One thing, you're not building a house so for less weight to tow you could get a sturdy rig when the top and sides go on. I built my first one with 1x2's, 2x2's, 1x3's with luan both interior.exterior. Plus your cabinets and counter will add more sturdiness than you'll imagine. First time builders have a habit of overbuilding, plus those bigger boards cost $$$.
Til later by the fire--John T. & Linda 8)
John T. Hodgen
Re: New WV build
Postby Ned B » Sun Feb 24, 2013 11:33 am
Looks like you've made some great progress!
Great avatar btw, I worked a lot in WV last year before i relocated back to NY, and I had a 'thing' with bridges in WV (there are SO many of them) Nice shot of the new river gorge bridge! I won't clutter up your thread with bridge shots, but if you're interested, I did a post on a shoot I did at the NRG last march... http://photocamel.com/forum/365-projects-photo-day/150963-road-shots-366-2012-a-45.html#post1525292 check out that link to see some shots from that day.
Ned B
Re: New WV build
Postby KCStudly » Sun Feb 24, 2013 9:21 pm
Link to links of pics would not open due to not being signed up.
Post them in your gallery and put a link to one of your own posts here, please.
Re: New WV build
Postby John T. Hodgen » Mon Feb 25, 2013 7:11 am
Yep, Ditto on the links not working unless you sign up. :( Yakangler, if you look at my photobucket link at the bottom of my signature, you'll find pics of my build, camping on Cranberry River, our Fall Foliage Gathering and other stuff. Like camping below the Summersville Dam. I hope that you'll join us in Oct. I can send you a Mountaineers of West Virgina Chapter sticker to start your collection. Just pm me your address.
John T. Hodgen
Re: New WV build
Postby Ned B » Mon Feb 25, 2013 5:32 pm
whoops, sorry about that gang:
and/or check out http://nedsroadshots.blogspot.com/2012_ ... chive.html which leads to a blog I put up about my photos...
Ned B
