gallery/image.php?album_id=2875&image_id=102442&view=no_count
(Click pictures to see it larger in a new window)
to those it may concern and to explain the past tense; I am begining this build journal nearly midway through construction. I feel i've come over the hump of uncertainty and the pace is starting to quicken.
I knew i wanted to fit a queen size bed in my trailer and therefore I needed a 5 foot wide frame. As some of you may know the only 5 x8 trailer available for under $500 is the northern tool trailer for around $420 and that seemed a little pricey to me, and i thought i could save some money if i found the right used trailer. I found a 5 x 7 for around 200, but it desperately needed a rebuild and still needs new tires (the northern tool trailer would need new tires for a speed rating over 45mph). It was a lot of work and time. And in the process I thought i messed up, blew my budget and was starting my build off way to heavy. But after i finished, i came out with a solid foundation that fit my needs exactly.
The Rebuild
Cutting that nasty tongue off
gallery/image.php?album_id=2875&image_id=102454 gallery/image.php?album_id=2875&image_id=102453
gallery/image.php?album_id=2875&image_id=102430
New Tongue
gallery/image.php?album_id=2875&image_id=102456 gallery/image.php?album_id=2875&image_id=102457
gallery/image.php?album_id=2875&image_id=102458
Adjustable Coupler
-extremely convenient if you are switching tow vehicles
$50 ebay
gallery/image.php?album_id=2875&image_id=102461 gallery/image.php?album_id=2875&image_id=102462
-tacked on
gallery/image.php?album_id=2875&image_id=102463http://www.tnttt.com/gallery/image.php?album_id=2875&image_id=102465
BEFORE_____________________________AFTER
gallery/image.php?album_id=2875&image_id=102445http://www.tnttt.com/gallery/image.php?album_id=2875&image_id=102444
gallery/image.php?album_id=2875&image_id=102442http://www.tnttt.com/gallery/image.php?album_id=2875&image_id=102443
BRINGrecycling
the goodwill for the creative and adventurous
Galley suports, door handles,
gallery/image.php?album_id=2875&image_id=102449http://www.tnttt.com/gallery/image.php?album_id=2875&image_id=102448
Windows
gallery/image.php?album_id=2875&image_id=102447http://www.tnttt.com/gallery/image.php?album_id=2875&image_id=102446
Solar Panels, shattered but they work
gallery/image.php?album_id=2875&image_id=102450http://www.tnttt.com/gallery/image.php?album_id=2875&image_id=102451
gallery/image.php?album_id=2875&image_id=102452
Floor
Framed with 1 x 3 and 1/4" *no added urea formaldehyde* plywood
gallery/image.php?album_id=2875&image_id=102466
Insulated with ridged closed cell foam
gallery/image.php?album_id=2875&image_id=102467
Extra insulated with a emergency radiant heat blanket
gallery/image.php?album_id=2875&image_id=102468
