OREGONtrial_2013
OREGONtrial_2013
Postby co.adams » Fri Feb 22, 2013 6:50 am
The beginning.
gallery/image.php?album_id=2875&image_id=102442&view=no_count
102442
(Click pictures to see it larger in a new window)
to those it may concern and to explain the past tense; I am begining this build journal nearly midway through construction. I feel i've come over the hump of uncertainty and the pace is starting to quicken.
I knew i wanted to fit a queen size bed in my trailer and therefore I needed a 5 foot wide frame. As some of you may know the only 5 x8 trailer available for under $500 is the northern tool trailer for around $420 and that seemed a little pricey to me, and i thought i could save some money if i found the right used trailer. I found a 5 x 7 for around 200, but it desperately needed a rebuild and still needs new tires (the northern tool trailer would need new tires for a speed rating over 45mph). It was a lot of work and time. And in the process I thought i messed up, blew my budget and was starting my build off way to heavy. But after i finished, i came out with a solid foundation that fit my needs exactly.
The Rebuild
Cutting that nasty tongue off
gallery/image.php?album_id=2875&image_id=102454 gallery/image.php?album_id=2875&image_id=102453
102454 102453 102430
gallery/image.php?album_id=2875&image_id=102430
New Tongue
gallery/image.php?album_id=2875&image_id=102456 gallery/image.php?album_id=2875&image_id=102457
102456 102457 102458
gallery/image.php?album_id=2875&image_id=102458
Adjustable Coupler
-extremely convenient if you are switching tow vehicles
$50 ebay
gallery/image.php?album_id=2875&image_id=102461 gallery/image.php?album_id=2875&image_id=102462
102461 102462
-tacked on
gallery/image.php?album_id=2875&image_id=102463http://www.tnttt.com/gallery/image.php?album_id=2875&image_id=102465
102463 102465
BEFORE_____________________________AFTER
gallery/image.php?album_id=2875&image_id=102445http://www.tnttt.com/gallery/image.php?album_id=2875&image_id=102444
102445 102444
gallery/image.php?album_id=2875&image_id=102442http://www.tnttt.com/gallery/image.php?album_id=2875&image_id=102443
102442 102443
BRINGrecycling
the goodwill for the creative and adventurous
Galley suports, door handles,
gallery/image.php?album_id=2875&image_id=102449http://www.tnttt.com/gallery/image.php?album_id=2875&image_id=102448
102449102448
Windows
gallery/image.php?album_id=2875&image_id=102447http://www.tnttt.com/gallery/image.php?album_id=2875&image_id=102446
102447 102446
Solar Panels, shattered but they work
gallery/image.php?album_id=2875&image_id=102450http://www.tnttt.com/gallery/image.php?album_id=2875&image_id=102451
102450102451102452
gallery/image.php?album_id=2875&image_id=102452
Floor
Framed with 1 x 3 and 1/4" *no added urea formaldehyde* plywood
gallery/image.php?album_id=2875&image_id=102466102466
Insulated with ridged closed cell foam
gallery/image.php?album_id=2875&image_id=102467102467
Extra insulated with a emergency radiant heat blanket
gallery/image.php?album_id=2875&image_id=102468102468
currently in the pacific northwest
co.adams
Images: 56
Re: OREGONtrial_2013
Postby NebraskaTeachr » Fri Feb 22, 2013 4:57 pm
Looks like you have a pretty good start. Enjoy the build.
Tim
NebraskaTeachr
Images: 53
Postby KCStudly » Fri Feb 22, 2013 5:08 pm
Looking good. :thumbsup: :applause: :thumbsup: :applause:
Do you have a profile in mind?
I know sometimes pictures make things look different than what they are in person, so I am sure that you can judge better for yourself, but I have a small concern about your tongue. In this pic it looks like the grinder took quite a chunk of the wall thickness just ahead of the point where the "A" comes together, just to the left and above the vice that is visible in the background (behind the cage), and to a lesser degree on the other side.
Maybe on the side not shown in the picture, too(?).
With the somewhat longer single tongue extension ahead of this point this will be an area of high stress concentration, and a good part of the reason I am concerned about the material loss there. It wouldn't be too much trouble to scab on a couple of fish plates to reinforce this area.
Maybe you could tell us how thick your main tongue tube is and gauge how much material was lost there. There have been a couple of tongue failures and near misses posted up on the boards and they do not look like fun experiences to me. I would hate to see you have a problem down the road.
Postby co.adams » Fri Feb 22, 2013 6:10 pm
Appreciate the concern. I went way over board on the steel for my tongue and it was a little thick for the welder I was using and I got a little carried away with beveling the edges. I think it was 5/16. I might reinforce it when I put a toolbox mount on. Thanks for the heads up
co.adams
Images: 56
Postby co.adams » Fri Feb 22, 2013 6:22 pm
The plan
102481
co.adams
Images: 56
Postby co.adams » Wed Mar 06, 2013 3:30 am
Chugging along here, piece by piece. Just started construction on the walls. I got a great deal on these hatch doors for twenty buck that i'm going to use for doors. Way lighter, much faster and painless. Also made my decision not to do the front window. This profile most likely looks confusing but keep in mind its unique. i will be attaching a trunk style galley to the back if you can see in the sketch above.
This is the frame, I still need to make insulation voids.
102991
Window and Door
102992
more to come, starting to make progress
co.adams
Images: 56
Postby co.adams » Fri Mar 08, 2013 9:06 pm
insulation voids and galley support
103079
co.adams
Images: 56
Postby co.adams » Sat Mar 16, 2013 1:11 pm
More ridged foam insulation and emergency thermal blanket
103281
co.adams
Images: 56
Postby co.adams » Wed Apr 10, 2013 1:00 am
getting the floor snugged up before i go and get it sprayed with truck bed liner
104506
co.adams
Images: 56
Postby Cummins01 » Wed Apr 10, 2013 10:24 am
Lookin good so far, keep it up :thumbsup:
-Brad-
If it doesn't fit......... get a bigger hammer.
Build Thread:
viewtopic.php?f=50&t=54285&p=987867#p987867
Cummins01
Postby co.adams » Fri Apr 26, 2013 2:10 am
Fish plates on and painted. I'm pretty glad I did it, makes me feel better just lookin at it. Thanks for the advice KCStudly.
105409
Finally the walls
105408
co.adams
Images: 56
Postby davidniebeling » Fri Apr 26, 2013 9:03 am
Lookin' good. I'll be following your posts. I love watching trailers that are a little different than the "standard" teardrop and I also love the idea of "recycling" parts. It makes a trailer more unique. :thumbsup:
davidniebeling
Images: 50
Postby co.adams » Mon Apr 29, 2013 1:49 am
Thanks David and everyone else has replied. My plan kinda evolved into itself and i'm really happy with it. I really enjoy the aerodynamics of the tear drop and i'm glad my build discovered a way to do that. It all fell together at the right time. Right now i'm focusing on making it road worthy and water tight. I'm stuck on what to seal with. I don't know if regular caulk will work on the seams or if i should get a heavy duty rv sealant. Also i have a couple small holes to patch and i'm wondering what to use.
105601
Before_________________________________________________________Currently
102442 105600
better view of the rear
105602
better pictures to come
co.adams
Images: 56
Users browsing this forum: Bing [Bot] and 14 guests
