Broken Bow Offroad build
Postby bpalmer » Thu Aug 29, 2013 8:58 pm
110420110421
few pic of the build i started more to come soon
bpalmer
Images: 61
Re: Broken Bow Offroad build
Postby rebapuck » Thu Aug 29, 2013 10:10 pm
It's a start. Probably won't be ready for this year, but you have all winter to work on it.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby bpalmer » Fri Aug 30, 2013 7:57 am
Hoping to finish trailer this weekend have one fender and running board already on will be installing other fender, trailer lights and spare tire carrier on this weekend.... the heat here in SE Oklahoma is brutal right now its a slow go... hoping to have it done by spring!
bpalmer
Images: 61
Postby aggie79 » Fri Aug 30, 2013 9:19 am
Good start bpalmer!
Have you signed up yet for the Beaver's Bend outing in April? Even if you aren't finished we'd love to have y'all there.
Take care,
Postby bpalmer » Fri Aug 30, 2013 9:09 pm
Tom we haven't signed up yet ,we live about 10 minutes away so we will be around
Bob
bpalmer
Images: 61
Postby bpalmer » Sat Aug 31, 2013 11:32 am
111729111728111727111726111725111724
Got a little done this morning before the heat ran me into house! gotta help Angie do some canning garden really making right now
Bob
bpalmer
Images: 61
Postby rebapuck » Sat Aug 31, 2013 12:02 pm
Well, that was fast.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby bpalmer » Sun Sep 01, 2013 1:26 pm
been busy got a few more updates
111770
Side view
111769
Rear view shows jacks,receiver and the running boards will hold propane tanks
111767
Shows area were the fresh water tank and pump will mounted in plywood box under floor
111766
Spare tire carrier
111763
Area were two under floor storage boxes will be located
111768
Tow vehicle
bpalmer
Images: 61
Postby bpalmer » Sun Sep 08, 2013 12:40 pm
modified the linkage to spare tire carrier so i could use the lug wrench to lower it without getting under trailer112038
bpalmer
Images: 61
Postby bpalmer » Fri Sep 20, 2013 11:59 am
112483
rough drawing of camper
bpalmer
Images: 61
Postby KCStudly » Fri Sep 20, 2013 12:35 pm
Great start!
Makes me wish I had thought a little harder about locating a water tank near the axle (it's not too late yet, but...). I like the idea of the propane tanks being mounted on the backs of the fenders, too. Get's all of the variable weight near the axle so that your tongue weight is affected less by consumption. My guess is that having the propane on the tongue is more common because it is the safest outside location and is away from potential impact damage.
Taillights and fenders on trailers have a tendency to bump into things. :roll:
Looks like your fender platforms are fairly robust. Is that box tube under the edge?
On my car trailer I built cup like holders for the round taillights out of sections of heavy pipe; slotted a section around the perimeter so that the lens could be seen from the side; then mounted it to the trailer with a thin gauge piece of sheet formed into an angle tab. That way if they should happen to bump into something they will yield at the thin tab, but will protect the light fixture from damage.
Postby KCStudly » Fri Sep 20, 2013 12:36 pm
Meant to ask what is the compartment under the rear of the tongue box? I can't quite make out the text at this resolution.
TIA
Postby bpalmer » Fri Sep 20, 2013 12:50 pm
I used 2 pieces of 2.5" angle under the running boards that is welded underneth the channel frame so should be there!! If your looking at the drawing there is a small box on tongue then a build in box at front of trailer that will house the AC unit and batteries with space above for storage. the AC unit will basically sit on top of the spare and be open underneth for it to get air with the batteries sitting in each front corner
Bob
bpalmer
Images: 61
Postby KCStudly » Fri Sep 20, 2013 1:53 pm
You going to section the batteries into separate compartment(s) from the A/C right? :thinking:
Batteries (especially wet cells) give off hydrogen when they are charging and I would think that you would want to keep that away from your A/C, especially if planning to use the outside air vent feature. The little units still have that feature, right?
I suppose the modern units must be less of a concern for sparking/arcing with sealed motors and solid state circuits, but... ? :thinking:
Also, if you haven't already, you may want to take a look at how others have done there A/C installs. Many have run into more problems than they expected when they partially enclosed their units. I think Planovet had good success with his thru the floor vented unit in the Little Swiss trailer.
I'm sure you have everything well thought out and under control... just saying. 8)
Postby bpalmer » Fri Sep 20, 2013 4:23 pm
Yes the battery compartments are separate from the AC unit and will have a vents similar to a bass boat. I'm copying Planovet design except in front box instead of galley. the trailer is 5x12 the front 2 ft is the box that gives me 5x10 is for the camper i,m gonna use a Haire unit that blows out the top at about 45 degrees and small wall or headboard to keep mattress out in front of unit by maybe 6 or 8 inches so it can get return air this will also allow me some storage on both sides of the unit inside the camper.
I appreciate the feed back though I'm sure I'll need all the help i can get lol :D
Bob
bpalmer
Images: 61
Users browsing this forum: Bing [Bot] and 12 guests
