Teardrop Smells? - Chemically Sensitive looking for a TD!
...if you find a Teardrop or Tiny Travel Trailer, on Ebay, craigslist, etc, post it here.........
Postby jpod » Wed May 18, 2011 12:23 pm
Hi,
I just recently discovered teardrops. It was love at first sight.
The challenge is that I'm really sensitive to chemical and wood smells. Really, any noticeable smells can be a challenge for me.
So, here are my questions:
-Does your brand new TD smell a lot??
-If you have a teardop that's a few years old, do you notice any smells?
-Are teardrops prone to mildew smells?
-Any other odor-insight would be really helpful.
(It's also tricky to sniff-test teardrops, because I live in Boston, and it doesn't seem like there's much used or new teardrop activity in this part of the country.)
But I remain hopeful and excited about a teardrop!
Thanks so much!
Kyle Elizabeth
jpod
Postby Kens » Wed May 18, 2011 12:56 pm
Wellcome to the madhouse. Tds do smell when first made. Glue ,varnish ect. This in time all goes away. Mildew only if you have a leak then you have a problem. Go to a gathering and smell around :lol:
Good day every day!
Kens
Images: 26
Postby fireaunt » Wed May 18, 2011 7:06 pm
Smell and reactions are subjective and depends if you are allergic or not.
I am sensitive to the finishes and dyes in material. I generally don't have any problems with my tear. Sealing the tear will keep the water out but I found before I insulated the floor, there was some condensation on the underside of the mattress. There are moisture absorption devices you might check out.
You might also check out the fiberglass units. I would have to air out some of those because of the carpet they use which has finishes which I am allergic to.
fireaunt
Images: 38
Postby Shadow Catcher » Wed May 18, 2011 9:16 pm
I am sensitive to smoke, and after a truly disastrous experience at Chain O Lakes (camp fires=smog) started looking at air filters and found a 12V three stage powered filter that should help. This should also help with chemicals etc.
One other suggestion is find a smell you like i.e. cedar and make sure that is the predominant one via wood shavings or construction or what ever you lake using a sented oil or...
Postby jpod » Fri May 20, 2011 5:44 pm
thanks for the thoughtful replies!
jpod
Return to For Sale(not mine)
