Bought a Pop Up frame today..on my way.
Postby rustytoolss » Tue Aug 30, 2016 3:58 pm
Just bought a small pop up frame today. 8) It's a bit shorter than what I had wanted. But that's not a problem. It came with two spare tires and wheels. I also got 4 camper Jalouise widows W/screens and trim ($10.00ea). So I'm getting parts for my project .
Got a question. When you guys lengthen a HF frame with 2x4's do you use treated lumber ? The pop up frame is 6x7. And I want to make it 6x9. I might just weld the extension, and not use 2x4's :thinking:
Mostly Old Parts And Rust= MOPAR
rustytoolss
Re: Bought a Pop Up frame today..on my way.
Postby ghcoe » Tue Aug 30, 2016 6:51 pm
You will need to watch your axle position. On some pop up trailers the frame extends past the wheels which makes it difficult to move the axle back without a lot of cutting and/or welding. If you lengthen the trailer you will probably need to move the axle back.
On my old '57 Kenskill camp trailer the body extended past the frame 2'. They just placed a longer floor on the frame that was supported by just 2"x2". Seemed to be plenty strong. 2"x4" always screams "HEAVY" to me.
George.
ghcoe
Postby rustytoolss » Tue Aug 30, 2016 7:24 pm
If I lengthen the trailer. I will add one foot to each end. I would think that by doing that, the balance should be OK. But I will have to check the pinch point. So the front corner will not contact the TV in a sharp turn. But it looks like there will be enough room. It also has a torsion axle :)
rustytoolss
Postby ghcoe » Tue Aug 30, 2016 8:52 pm
That would work fine as long as the pinch point is good. :thumbsup:
George.
ghcoe
Postby OP827 » Tue Aug 30, 2016 10:28 pm
You can also reduce the pitch point by making the front corners angled, like a blunt V-nose.
OP827
Images: 414
Postby Camp4Life » Wed Aug 31, 2016 9:09 am
Congrats on the acquisition! :thumbsup: Looking forward to seeing your progress :beer:
Camp4Life
Postby rustytoolss » Wed Sep 28, 2016 6:22 pm
Finally got my bare pop up frame weighted to day, 220 lbs. Lighter than Harbor Freight, and I have a Torsion axle :) 6x7. I'm going to make it 76"x 9'6". I will start buying materials soon. Should be starting mid October-early November.
rustytoolss
