aggie79 wrote:Mel,
I think a router would work fine as to what you want to do. The trick is to use a guide bushing in the router and a template. As far as the router bit, I would try a spiral bit. If you can find one in high strength steel, that would be the one to get rather than than a more-expensive carbide bit.
There are many bushing/bit combinations, but for ease of explanation (and which is the setup I use) let's go with a 1/4" spiral bit and a 3/4" bushing. The bushing rides against the template - 1/4" material of your choice. This means the cutting edge of the bit is 1/4" away from the bushing. So, if you want a 3" round recess for a hardpoint, you'd need to make the hole in the template 3-1/2" in diameter (1/4" each side).
Set the template in place and fasten it somehow. On wood, I used double-sided tape to stick the template in place. Then set your bit depth and route away.
I wish I could describe things better in words. Please forgive me if you aready know how to do this technique.
Thanks,
I'm thinking along the same lines, the template idea works just fine. I also got lucky the other day and found a small hand held trim router that I got from my dad's house as we cleaned it out and moved him into a home a few years ago.. At that time I got a couple of big boxes of tools. As amazing as it seems in my fuster cluck of a garage, I found it. so no need for a new tool.
I tried the template technique and it worked great, the router worked great and I used 2 part epoxy to glue the plywood in. I think the plywood will separate before the epoxy fails. Thanks for the two sided tape idea! Worked like magic.
Problem solved... Thanks Guys!!!!
Mel
The Road Foamie Build Thread:
viewtopic.php?t=45698
