Grits,more work getting done
Re: OK, here goes: Grits
Postby Mary C » Wed Jul 10, 2013 8:04 pm
Got a little done lots of glueing, I tried to use GS as much as possible because that will dry at a higher humidity but it was 75% humidity today. I have to glue canvas on the doors tomorrow. I was going to do it today but the rain and all the lightning didn't help I am going to try to glue both doors tomorrow Morning. I have three more pieces of 1/2 inch foam to glue on then the second layer of foam on the hatch and the roof. then overnite drying and then canvas. canvas the sides, top and hatch. I am hoping I can do it by Friday if the rain will hold off . then let it dry dry dry.
Mary C. :)
Mary C
Images: 473
Postby GPW » Wed Jul 10, 2013 8:30 pm
Best of luck to you Mary ... seems you have everything well under control .... but the weather ... Nobody can do anything about that ... not yet anyway ... :thinking:
Postby atahoekid » Thu Jul 11, 2013 4:22 pm
If I were to try it, I would just bevel cut the pieces, butt join them (both layers, if you're doing more than one) and sand them smooth to each other prior to canvas. That's a pretty sharp bend you're trying to make. :shock: The end result should look fine and I bet you're the only one who will know you did it that way! ;) :) :thumbsup:
Mel
atahoekid
Images: 158
Postby kudzu » Thu Jul 11, 2013 10:44 pm
Mary C wrote:Got a little done lots of glueing, I tried to use GS as much as possible because that will dry at a higher humidity but it was 75% humidity today.
Holy cow! Can't believe you managed to get any gluing done with all the rain yesterday. Good going on making any progress in this weather. It's crazy, like monsoon season.
kudzu
Images: 16
Postby Mary C » Thu Jul 11, 2013 11:46 pm
here are my pictures of glued areas.
109503
109506
109504
109507
109508
109509
you can all see my various clamps the most successful one, I think is the coleman stove!!! of course the chain saw bar oil makes a good argument for being the best too.
and yes I got it all glued somehow, it sorta rained then stopped I would do a little then it would rain again. this was over and over and in between I was going back and forth through grass that is knee high and wet. but you do what ya gotta do.
Mary C. :) :)
kudzu where bouts do you live you can pm me if you need to.
Mary C
Images: 473
Postby atahoekid » Fri Jul 12, 2013 12:57 pm
One can never have enough clamps. Yes, boxes of tile, paint cans, bricks, sandbags, power tools, buckets of water count too!!! :lol: :lol: :lol:
Mel
atahoekid
Images: 158
Postby kudzu » Fri Jul 12, 2013 1:40 pm
Do I see camo colored Duck tape in one of those pics? Hope the kerfing is going better.
Sending you a PM.
kudzu
Images: 16
Postby KCStudly » Fri Jul 12, 2013 1:58 pm
I assumed it was a camo colored ratchet strap. :thinking:
Postby kudzu » Fri Jul 12, 2013 2:06 pm
KCStudly wrote:I assumed it was a camo colored ratchet strap. :thinking:
Looking at a different pic I think you are correct. Funny thing, I've seen camo duct tape but not camo ratchet straps.
kudzu
Images: 16
Postby Mary C » Fri Jul 12, 2013 2:48 pm
Ratchet strap, used as a clamp it is amazing works great and yes it is camo I bought the cheap ones and they are really tough for me to use so I got the 16 foot more expensive ones they are great!!!! They work great as clamps and all sorts of other things.
Mary C. :)
Mary C
Images: 473
Postby Mary C » Fri Jul 12, 2013 7:48 pm
New pictures!: got the doors canvased and lots of other little things done
109611
109613
109612
109616 I plan to use a few of these on the hatch to make sure the foam doesn't
come off the hatch frame
Mary C. :)
Mary C
Images: 473
Postby Mary C » Fri Jul 12, 2013 8:10 pm
I have not built anything in a long time and I was having a hard time sawing a straight line, something was messed up on my saw :( and in order to saw straight I had to just watch the blade. .......I cleaned the saw dust off this one part of the saw and I found a place to do an adjustment.
Well I got a special ruler with 64th on it, and I went to adjusting. now it will saw straight. I had forgotten all about the adjustment. I was going to give it away ......Not now. :D
109618
Mary C. :)
Mary C
Images: 473
Postby Wobbly Wheels » Sat Jul 13, 2013 12:25 am
You're doing great Mary - it's great to see it coming together the way it is. I'd love to be making that kind of progress.
...in order to saw straight I had to just watch the blade...
I've spent plenty of time driving a skilsaw and , I gotta say, nothing's better for seeing your cut than...actually seeing your cut.
Doesn't that sort of thing make you feel like a champ ?
Or is that just me ? :lol:
ImageI plan to use a few of these on the hatch to make sure the foam doesn't
Just a thought, but if you stack a SS screw, a finish washer, and a fender washer, you'll get something that you can leave exposed and you won't have to worry about nails 'popping' over time.
atahoekid wrote:One can never have enough clamps.
True dat...but....it can be done, even with 'thrifty' in mind. They don't work everywhere, but where they do it's an almost free way to have a whole box full of clamps made of scraps of plastic pipe:
You can play around with the width of the cut and the length of the piece to adjust the clamping force to be whatever you need. I use 1/8" doorskin scraps to keep from digging into the foam.
I like that this saves my F-clamps and pipe clamps for where I really need them. They excel at laminating strips together, but they also work really well on edges of panel glue ups.
Wobbly Wheels
Postby CliffinGA » Sat Jul 13, 2013 5:24 am
Kudzu we're in Game by God of course we have camp duck tape and ratchets!!
Mary looking good mam hope you get a lot more done n next few dayes.
Cliff
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby GPW » Sat Jul 13, 2013 6:22 am
W2, Good ideas ... writing them down !!! :thumbsup:
