aggie79 wrote:Thank you for this thread. I'm still interested in the foam core construction but had concerns about delamination regardless of the adhesive.
You've probably already said this, but I've seen other places recommend a light coarse sanding - 60 or 80 grit - to give the slick "skin" of the insulation some "tooth" for whatever adhesive.
pete42 wrote:The wings on my fiberglass airplane flexed as do all wings and the core foam never separated from the fiberglass.
How much flex are you talking about there is way more stress exerted on a planes wings than on a foamy.
I think we are right back on the same subject as the other thread.
neither I nor anyone else knows the answer to what caused the blister we can go around this again and again
but the real test is when we all meet at Louella's and rip the bad canvas from her tear...........I'm sure she won't mind
anyone want to volunteer to go first Steve? Glenn? I would but I'm chicken.
Pete
on those chopped fiberglass pieces where I worked in bye gone years we use asbestos as a binder in the plaster mix then we went to the fiberglass pieces.
Be very careful handling them ingested they don't dissolve and can cause cancer.
linuxmanxxx wrote:My thoughts are the delamination is being caused by hardness factors. Both tb2 and epoxy dry to very hard coatings with no flexibility properties at all and if the foam which is a very flexible component flexes in any way the nature of the glue would be to delaminate and break away from the foam.
So that said a hard but flexible coating would be the answer but still have very high adhesion to the foam. The plasticore stuff has shown to have these properties but is quite pricey and have to be relegated to a high end coating. I haven't played with my foamcoat and bounce additive yet and will do all that soon after I move but the troweling aspect is a buzz killer on that one for sure.
The zoopoxy place has a flexible epoxy and I will email the president back and kick around how hard it gets and pricing on it as he quoted a hard shell epoxy to me.
So not being argumentative but do you understand what I mean by a flexible glue wouldn't delaminate just because of its properties to give and take? That is where I think the holy grail will come from is figuring one that will flex and not break the bank paying for it but still have hardness to go with the flex.
