mezmo wrote:A good approach for these, I think, would be to build the door and it's frame as
a sort of mini prehung door. Build the door, then build the case/frame around
it with the clearances you want, then install that 'unit', and then build/frame the wall
to fit that. Much less aggravating than trying to build a door to fit a pre-existing
opening.
Norm/mezmo
GPW wrote: Ps . I could see using Masonite for the interior facing on the door frame not only as a Trim feature, but a place to attach the gasket..
