5x9 Hybrid
Re: 5x9 Hybrid
Postby TJinPgh » Wed Sep 12, 2012 3:14 am
As an aside to that, I would be curious to see if anybody had ever done any tests on whether or not a curved roof is any less prone to sagging than a flat one.
It's been my experience that structural panels rarely flex in both directions at the same time. At least, not on their own.
Might well be possible to go thinner on a roof with a curve.
-TJ
TJinPgh
Images: 90
Re: 5x9 Hybrid
Postby GPW » Wed Sep 12, 2012 4:47 am
The curve is stronger, much as corrugated tin is stronger than a flat sheet ... an arch stronger than a box ... old technology ...
Re: 5x9 Hybrid
Postby atahoekid » Thu Sep 13, 2012 11:13 pm
Wish I had thought of that during my build. I had to work pretty hard to make sure my flat roof didn't sag (2" foam, 7 feet wide). I ended up putting 1 x 3's on the flat to prevent the sag. A little arch in the roof would probably have made the added support unnecessary but probably would have made the seam between the nose and the roofline harder to manage
Mel
atahoekid
Images: 158
Re: 5x9 Hybrid
Postby TJinPgh » Fri Sep 14, 2012 7:35 am
Well, unfortunately, anything bigger than a 4x8 with a flat roof is going to have a seam in the roof somewhere unless you're skinning with aluminum or something that you can get in a wider width.
-TJ
TJinPgh
Images: 90
Re: 5x9 Hybrid
Postby GPW » Fri Sep 14, 2012 10:32 am
TJ, Not to Worry !!! A seam is just another place for a “reinforcing strip” ... :thumbsup: Got 2 seams in my roof ... no problems !!! ;)
Re: 5x9 Hybrid
Postby KCStudly » Fri Sep 14, 2012 8:46 pm
Oh the power of the mighty arch....... and GG to stick the foam together. 8)
TPCE, as many of you know, has a gentle arch throughout the whole roof lengthwise. 5ft wide (flat from side to side...well, 64 inch really) with integral spars buried in the foam at the roof vent, and structural support from the cabinet face frames underneath front and rear. I don't expect any problems... but who knows, "ain't got there yet". :lol: :D
Re: 5x9 Hybrid
Postby atahoekid » Fri Sep 14, 2012 11:55 pm
KCStudly wrote:Oh the power of the mighty arch....... and GG to stick the foam together. 8)
Well, I hope you don't have any problems cuz that's how I planned and built my roof (without the arch). So far, I am amazed by the structural strength. I think you'll find your foamie amazingly rigid.
Mel
atahoekid
Images: 158
Re: 5x9 Hybrid
Postby Wobbly Wheels » Sat Sep 15, 2012 12:36 pm
I took the arch out of my roof, mostly because it looked awful. The center section was about 4X6 and had a healthy curve across its width - about 3" higher in the center. I won't be walking around up there so I opted for the easier glassing of a flat panel.
I have an array of four 15W solar panels to go up there, but they will be mounted flat on glassed foam rails that carry the loading out to the side walls.
That said, I'm also using glass rather than canvas so potential seam problems aren't an issue.
Wobbly Wheels
