mike, i did hide one side of mine, at least i tried to. never got around to the other side. it turned out to be a pita the way i did it. my seam was on the roof.
i do believe that someone did with using foam: was it athoekid?
on my second one i will put the seams on the sides, you could then use covered foam to stick on and hide the seam. and if done right could double as a rain gutter?
