GPW wrote:Zach , I just need to fit the cabin onto the frame and see where everything falls out ... a little forward would be OK for me too ...
Chart , I’ve got those bits and if we HAVE to , I’ll move the axle ... just not as yet ... Have to recover from the build first ...
Tiredoldwhiteman wrote:GPW wrote:Zach , I just need to fit the cabin onto the frame and see where everything falls out ... a little forward would be OK for me too ...
As light as your Foamer is, placement on the trailer would seem to only be a concern as to access...
Light (weight); its a good thing...
chartle wrote:Isn't axle placement more of a weight distribution then a overall weight issue.
GPW wrote:TOWM , just thinking cause’ I got the 1195 lb. trailer The springs will be light enough so it won’t be Bouncy .. sans Beer ballast ... The cabin is pretty light ... the other day a friend and I moved it , just the two of us ... it was heavy , but no backbreaker ... May not be 250lb . like I guesstimated ...
Gosh!!! I’d hate to run under weight ... More ballast !!!
HF is now back in my picture , only because I have an “In “ at the store ...
GPW wrote:...The springs will be light enough so it won’t be Bouncy .. "
GPW wrote:"HF is now back in my picture , only because I have an “In “ at the store ...
