Harbor Freight's Out of the Picture
Postby eaglesdare » Mon Nov 28, 2011 6:18 am
:applause: :applause:
Louella
May the foam be with you.
eaglesdare
Postby GPW » Mon Nov 28, 2011 6:33 am
Thanks everybody !!! I’m Happy to have it , and have it done ...
Chartle , I can’t see moving the axle back unless I do some serious drilling , and then as you say there needs to be something (brace) for the middle ... The hinges that I left won’t do it ... I’d love to move the axle back about 10â€
Postby absolutsnwbrdr » Mon Nov 28, 2011 9:20 am
Looks good GPW!
You going to start your own build thread, or continue to run this one out of control? :lol: :lol:
FWIW - I didn't move the axle on either of my trailer builds. Both are longer than the 8' trailer frame, and sit forward on the frame a little bit.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby chartle » Mon Nov 28, 2011 9:21 am
[quote="GPW"]Thanks everybody !!! I’m Happy to have it , and have it done ...
chartle
Postby chartle » Mon Nov 28, 2011 9:45 am
[quote="GPW"]
The fender is about 3â€
chartle
Postby GPW » Mon Nov 28, 2011 10:35 am
Zach , I just need to fit the cabin onto the frame and see where everything falls out ... a little forward would be OK for me too ...
Chart , I’ve got those bits and if we HAVE to , I’ll move the axle ... just not as yet ... Have to recover from the build first ...
Postby Tiredoldwhiteman » Wed Nov 30, 2011 5:08 pm
GPW wrote:Zach , I just need to fit the cabin onto the frame and see where everything falls out ... a little forward would be OK for me too ...
As light as your Foamer is, placement on the trailer would seem to only be a concern as to access...
Light (weight); its a good thing...
Tiredoldwhiteman
Images: 5
Postby GPW » Wed Nov 30, 2011 6:07 pm
TOWM , Last night I had the guys help me move the cabin so I could apply the nasty black stuff underneath.. 4 guys easily picked it up with no strain at all ... Got it coated today , and let it sit out towards the sun , and it appears to be dry -ish already ... Light is good as I was easily able to flip it over (by myself) on it’s side onto an old moving blanket for access to the bottom.
I measured and only 8â€
Postby Tiredoldwhiteman » Thu Dec 01, 2011 2:42 pm
[quote="GPW"]... room for a small 8â€
Tiredoldwhiteman
Images: 5
Postby GPW » Thu Dec 01, 2011 5:32 pm
Continental kit ... That’s Perfect !!! Great idea TOWM !!!!! 8)
Postby chartle » Fri Dec 02, 2011 5:23 pm
Isn't axle placement more of a weight distribution then a overall weight issue.
chartle
Postby Tiredoldwhiteman » Mon Dec 19, 2011 3:04 pm
chartle wrote:Isn't axle placement more of a weight distribution then a overall weight issue.
Indeed...However, I was mostly just funnin' with G because his foamie is so bloody light weight...
Tiredoldwhiteman
Images: 5
Postby GPW » Mon Dec 19, 2011 8:44 pm
TOWM , just thinking cause’ I got the 1195 lb. trailer The springs will be light enough so it won’t be Bouncy .. sans Beer ballast ... The cabin is pretty light ... the other day a friend and I moved it , just the two of us ... it was heavy , but no backbreaker ... May not be 250lb . like I guesstimated ...
Gosh!!! I’d hate to run under weight ... More ballast !!! :o
HF is now back in my picture , only because I have an “In “ at the store ... :roll:
Postby swampjeep » Tue Dec 20, 2011 3:09 pm
GPW wrote:TOWM , just thinking cause’ I got the 1195 lb. trailer The springs will be light enough so it won’t be Bouncy .. sans Beer ballast ... The cabin is pretty light ... the other day a friend and I moved it , just the two of us ... it was heavy , but no backbreaker ... May not be 250lb . like I guesstimated ...
maybe they are putting the 1195, as the 1500 minus the weight of the trailer? guessing a rough 300 with some type of floor? if used as a ordinary util,
swampjeep
Postby Tiredoldwhiteman » Wed Dec 21, 2011 12:31 am
GPW wrote:...The springs will be light enough so it won’t be Bouncy .. "
Soft springs are a necessity for such light-weight trailers...Are there any calculations/charts, etc available to determine how light or heavy one's springs need be?
GPW wrote:"HF is now back in my picture , only because I have an “In “ at the store ... :roll:
I'm still looking for an acceptable trailer...Most everything is way too heavy, too expensive, sans title or so bad it'd cost twice its worth to be made road-ready...Patience Grasshopper.
I nearly broke down the other day thinking to call the HF store, but I held strong ;-)...
Tiredoldwhiteman
Images: 5
