Wobbly Wheels wrote:FYI Mel, if you pick up a ratchet crimper and use nylon-insulated rather than pvc-insulated terminals, weak crimps will be a thing of the past. Solder takes longer and can be problematic in an environment subjected to vibration.
Yeah, I was worried about what to do if a wire goes bad. Fish tape and wire in a pvc conduit should make things easier to pull and replace. I'm really hoping to do a good job of wiring so that chances of things going wrong are minimized.pete42 wrote: ...some have used stranded wire run in pvc conduit that way if a wire goes bad it can be pulled out and replaced.
pete
