I've been plugging along, as I can. It's turned very hot and humid here, so everything is taking forever to do. Got on a full edge on the aluminum bent. Not sure it will lay flat. I"m torn with what to do. That clamp helped loads. Not giving up, just
out loud. Can someone please point me to a how to anneal aluminum? Step by step for dummies version please. Required tools list would help, too.
Bright side is I got the first cedar part finished waterproofed. Flipped the door over and will begin side 2. The mix is taking awhile to dry, so each coat is paint it on, let it set. Looks good though, so I'm trying to be patient.
Hit several yard sales today. Got the bottom for my dutch oven stand (walker and satellite dish version). $2. Legs adjust and it folds flat.
Then I found some closed cell foam stuff that will work for the door seal. $1. Will need to be glued or taped on. Found the LN 201 finally, so I'm good to go there. When the time comes.
Also got a door bell of sorts. It was not cheap, but I liked it a lot. You'll have to wait on the
until I can figure out if I can use it.
Still got family stuff taking away my build time, but family comes first. I get in a bit of progress here and there. It will get done, just not at lightening speed.
