When I cut the blanks I measured the opening at both ends of the spars and set the rip fence to the widest measurement. From there I just used the coarse/larger sanding block to scuff one edge of the foam until it would squeeze down into its bay. On the spar that is over the backer piece for the splice in the ceiling panel I used the 3/4 inch straight cutter and rip fence attachment on the trim router to cut rabbets along those edges. Here’s the router setup.
Here’s how that worked out. The one on the left is how I let it run off the edge about 1/8 inch to allow it to be sanded back fair after gluing. The one on the right is held back just to show the backer piece and rabbet a little better for the pic.
Here on the street side the pieces that fill the bay next to the roof fan were cut to rough length with a straight edge and the steak knife.
The foam is a little higher than the spar here, and using a scrap I can tell that it will be in other locations, as well, but not everywhere. Not sure if I will try and sand all of this to the profile, or try to shave the panels with a hot wire before install.
On the curb side I ran the fan wires up thru and used the router to hog a trough. Once this panel is glued in I’ll tape over the wire before gluing the top layer on.
Switched the router over to a 1/2 inch cutter, transfer marked the wire holes for the ceiling outlet from the spars to the curb side foam panels, removed them, and cut the troughs for those wires; shown here after dry fitting the foam again.
Decided I had better mark the panels for location and orientation, ‘C’ or ‘S’ for curb or street side, 1 thru 6 corresponding to the spar bay front to rear, ‘B’ or ‘T’ for bottom and top, and an arrow indicating front.
For the ceiling outlet I laid out both the box and the stiffening flange, as well as for the backer for the ceiling panel longitudinal splice over the rear cabinets. With the router set to full depth, I used a scrap of the busted up pink foam as a sacrificial cutting surface and free handed out the hole for the outlet. Then reduced the depth and free handed out the rabbet for the flange and along the middle edge.
After trimming the corners square with the steak knife, I flipped it over and cut the trough were the wires enter the box knockout, using the sanding block to open the edge up a bit.
The bay behind the fan (in front of the ceiling outlet) has a backer were the panel is spliced over the rear cabinet face frame and another longitudinal backer. These are the dado and rabbet for one side of those. I used a straight edge clamped on to guide the dado but just free handed the rabbet (which is easy to do in the foam because it does not try to pull the router at all).
Progress. You can see the little 3/4 inch fillers down the middle.
A little better look at my reference marks and you can see how I let the panels run off the edge a bit.
Progress.
Next I will finish piecing together the front wall foam. Before I start ripping the full width pieces for the top layer, I want to do the hatch first to prioritize the larger panels.
