foam builds (foamies that have been built or in the process)
Postby GPW » Wed Jan 25, 2012 9:07 am
I guess to add a foot overall you need to start measuring from where the cabin meets the metal box frame, 2â€
Postby GPW » Wed Jan 25, 2012 9:14 am
Oops !!! My Bad Math .... I think you’re right ... 10 “ ... 6â€
Postby GPW » Wed Jan 25, 2012 9:29 am
Just searching the net , see a LOT of metal corner brackets ... thinking it would be easy to get a dozen or so and have at it .. Thinking you could overhang the front of the trailer in the same way (longer) if well braced...
Ya’ Know , the more we reinforce/Brace/ bolt/weld/fix this to the trailer box , the more the idea of a removable cabin quickly fades from sight... :o Bolted and braced as we envision , I can only imagine someone of British descent having the ability to take it apart and re assemble it ... :R
Postby eaglesdare » Wed Jan 25, 2012 9:41 am
i have been thinking about this removeable aspect. i can't get it thru my head how to cover with canvas if its alread on the frame. the side rails will prevent that.
Louella
May the foam be with you.
eaglesdare
Postby GPW » Wed Jan 25, 2012 11:20 am
It’s covered long before the side reils (see what I mean ? Spell check ) go on ...and they get covered over too ... “the Sock “ All except the Aluminum angle iron that acts as the “runnersâ€
Postby eaglesdare » Wed Jan 25, 2012 12:35 pm
the side reils (hehehe) are already on. if bought pre-assembled. which at this stage i believe that is exactly how it will be.
so the covering will have to be done off frame, then moved onto frame and bolted.
Louella
eaglesdare
Postby GPW » Wed Jan 25, 2012 5:10 pm
Sorry , I got confused about what reils ‘ .. :oops: Yes, covered then it goes on the trailer .. same as usual ... I think ???
Postby linuxmanxxx » Wed Jan 25, 2012 5:41 pm
Now you need to readjust a bit on your specs if you take into account the inner width of the trailer is 5' and if you want an inner cabin width of 6' you need to add additional overhang to account for your wall width on each side. So if you build the outer ledges with a sandwich core luan top and base you would give it strength plus lighten over the just plywood option and add more stiffness over the plywood as well just a thought.
linuxmanxxx
Images: 10
Postby GPW » Wed Jan 25, 2012 5:46 pm
Dang Steve... that’s 2 great ideas in the same day ... :o 8) :thumbsup:
Postby linuxmanxxx » Wed Jan 25, 2012 5:48 pm
What exactly trailer did you buy and I didn't see this new page before I said go to 6' inside as glen mentioned this and I didn't see till after I posted. I'd still strongly suggest using a sandwich method for all the lower floors walls and shelves giving a much much stronger lighter box in the end. If you do that just get the 3/4" dow at lowes or pink corning at home depot with the cheap white wood 1x2 at lowes and tb3 on the 1x2 to luan and I'd recommend getting a quart of 30nf to use on the luan to foam bonding and you'd have a bullet proof lower section and still very light.
linuxmanxxx
Images: 10
Postby eaglesdare » Wed Jan 25, 2012 7:05 pm
no trailer has been bought yet. still waiting on the refund.
Louella
eaglesdare
Postby eaglesdare » Wed Feb 01, 2012 7:16 am
ok, could you leave a space in the front? lets say a 5x10 frame, could you leave a foot in the front?
Louella
eaglesdare
Postby GPW » Wed Feb 01, 2012 9:11 am
You could ... but why?
Postby eaglesdare » Wed Feb 01, 2012 9:23 am
i was thinking of a space to hold my bike, or possibly storage spot for wet/dirty outside equipement?
Louella
eaglesdare
Postby GPW » Wed Feb 01, 2012 9:41 am
A bike rack may fit forward of the box... seems a good place for it rather than lose valuable sleeping /lounging space inside ... Big trailer , Big cabin ... 50sq.ft of floor space seems to be the Magic number !!! ;) Roomy , yet not Too Big ... You know !!
