Trogdor wrote:I found a halogen power supply which puts out 5A at 12VDC which works well, the wire still gets a tad hot tho, but I was thinking of wiring in a dimmer switch before the transformer which would allow me to reduce the current? That should work?
The stainless wire will also help I think!
Cheers
Trogdor wrote:Ah,
Atahoe kid, thanks for info, it makes sense that I don't want it too thin, something like .020 thick would be good? I plan on gluing it down and fixing it to the spars to make sure it won't delaminate as aluminium expands quite a bit and am not sure the glue will hold it in place.
