Not sure if I understood the drawing, but if you want to pull out the shelf, then turn it to the side, then you might be able to do what I did with my "extend and turn" generator mount.Mary C wrote:...Any ideas on how to mount a turn shelf. I want one that will turn out. I plan to make the shelf out of 1x8s with a 1x1 frame around the top How would I attach in one corner some type of hinge? I want to be able to stand at the back of the TD and twist out the shelf and put a brace under it . the mounting will go through 3/8 OSB and 3/4 pine plank. I am not an artist but see if you can understand this:
Mary C.
working on it wrote:(from 10-5-13, thread link: http://www.tnttt.com/viewtopic.php?f=42&t=57594&hilit=+generator+slide) It slides straight out about a foot, then rotates counter-clockwise so the exhaust faces the curbside (and exhausts 6" beyond the sidewall). A tubular steel brace fits under the slide out, and supports the weight while running/vibrating. The three drawer slides have the combined weight rating of 105lbs (the genny and swivel base weigh about 65lbs), and if the genny is only pulled out 8", the brace is not needed. I ran it for an hour in my garage, and the brace remained rock-solid throughout (the genny is rubber-mounted on the wooden slide-swivel bases, to minimize hard vibrations). I will try to get some pictures of the set-up in action, this weekend. The swivel feature was necessitated by the 22" space I put it in; if I had the typical teardrop rear slope, there would have been enough room to just slide it in and out.
