Norm, unfortunately I do not have wood sides therefor, there is no way to obtain a top leverage pivot point for any type shelf. the sides are foam. the only secure place for attaching is the floor, a slide out would cut the room I have to have in order to reach things in the galley. I am short. I am not putting heavy weight on the shelf, I just needed the suggestion of a way to have the shelf swing out. it is not a box just a piece of flat ply wood. so instead of hinge I guess I should have said a "pivot point hinge" but my friend said that since i got the idea, now i need two slick surfaces so the shelf will slide I decided that I will just poly till it gets thick and keep sanding in between coats by the spring, depending on the humidity I should have enough poly to fill in the rough floor and enough to make it nice and smooth. Thanks for the suggestions from you and everyone else. I guess it is thinking out of the box once you know that I do not have any hard points on the sides. This is why I love the foam. It has given me a new perspective a new way of looking at things. keeps me young. It is a perspective that the typical wood TD builder does not have to deal with. If it was wood there would be lots of ways to connect and hinge lots of things could work, but having foam it has become a real challenge, to invent , design and to come up with ideas and it has been what has made it exceptionally fun. I have enjoyed all the suggestions and the thoughts on the subject. Building out of foam has its own sets of problems but I am concerned with getting the most inventive ways to have a working galley, designing the inside with unique storage and comfort things.
Sharon, I look at the hinges and looked up more, what i learned is that there are a lot of types of hinges. I plan to use a couple of them in the future. unfortunately most of them are designed to work on two or three planes which normally work but you gave me some more ideas and I thank you.,
KC, You are very smart and I appreciate your suggestions and concern. I promise the shelf will not be foam it will be sturdy enough for a little place to put the stove to heat up breakfast coffee and grits in a little parking lot off the beaten path. If there is a picnic table I will cook on that. I promise to build it sturdy
![Wink ;)](./images/smilies/econ_wink.gif)
, ain't no way my grits is going on the ground.
GPW Yes the legs problem is true
![Rolling Eyes :roll:](./images/smilies/econ_rollingeyes.gif)
but I think
![Thinking :thinking:](./images/smilies/econ_thinking.gif)
i have a solution. we will work on it. I am doing this design type stuff because others will come after and want to know how to do it with foam. You have been my inspiration.
![Wine :wine:](./images/smilies/wine.gif)
I am just so thankful we have wood builders following builds here and to support us as we wing it, giving us ideas and with kindness making us stretch to find solutions to our builds. and yes I am trying to keep it thrifty and to keep it simple.
For others, keep suggestions and ideas coming for all of us foam builders we may not use your suggestion but you give us the avenues to think, design and expand our thinking about foamies.
Mary C.
![Lady Smiley :lady:](./images/smilies/econ_flirting.gif)
