" Canvas is just too hard to get and too expensive” ...
We’ve heard that before ... Well, there is an alternative , and right under our noses ... Newspaper ...
(this should certainly stir up some discussion ) ..
I keep reading about the Foamie airplane guys using common newspaper and T2 as a covering material .. All reporting excellent results and achieving some Nice looking finishes , when painted ... and the usual strength/adhesion tests have been done on paper covered panels , the result similar to canvas ...
If you think about it , it’s not too far fetched .... Canvas is made of Cotton , cellulose fibers .... Newspaper is made of wood reduced to a pulp of , you guessed it , cellulose fibers ... In canvas , the fibers are woven , in newspaper the fibers are interlocked , same thing basically ...
Now admittedly , canvas is stronger , only because it’s thicker ... so to get the same strength , paper would have to be thicker , or just several layers of it applied ... The glue and paint make it waterproof ... The airplane guys apply the flat sheets to flat areas and for compound curves , use strips , and with plastic squeegees or old credit cards to do the smoothing ... The paper does tend to shrink slightly , similar to canvas, and results in a tight covering ...
Applied the same thickness as canvas , it would have similar strength properties , but the only advantage to paper is it’s sand able after it dries ... so smoothing becomes easy ... and being applied in thin layers , there would be no seams showing , so it would make a seamless finish ... something I’ve yet to discover with canvas , which frays when you cut it ...
So with a little sanding and a couple coats of primer , it should be easy to get a smooth uniform finish which would defy analysis . We’ve seen many MG floats done this way , and they look smooth as any fiberglass .. some Quite Old too ...
For those that would balk at the strength , of paper on the roof , one could easily imbed some steel chicken wire or hardware cloth under the covering on the roof ... which would pretty much eliminate any worries of stray falling limbs , meteorites , or frozen turkeys...
That would work with canvas too ...just for the overly cautious...
Food for thought ... Just a couple weeks of recycling should be enough material to make a nice smooth hard covering for most any Foamie trailer (or wood too) ... You already paid for the daily news , might as well just get some use out of it other than wrapping fish ...
Just another Thrifty Alternative ...
