Out of the many ways we’ve all tried , some just work Better than others .... I’m still Old school on this
... since we’re not doing mass production , it’s easy enough to assemble the foam parts first , then cover it ... Never chancing a mis-matched glue or paint confrontation . There seems to be an order to this , which if followed, produces predictable results as you have experienced
Seems the thing to avoid is a glue to paint situation.. lots of glues don’t stick to paint , and then the paint film is so thin , it offers little strength compared to it’s substrate , so may easily tear away (shear) ... And , some glues don’t stick to themselves very well .. was reading about T3 which once cured doesn’t stick well to a fresh coat of the same ..
We do know conclusively (now) that GG works for foam to foam , and foam to wood . Paint sticks to wood and canvas and combinations of both Very well . The Paint becoming the primary adhesive for the skinning process. T2 works too, but must be painted ... Can’t wait to try some Grabber... going to get some today ...
We also know that pre assembled panels have a tendency to warp due to the uneven shrinkage of the skin materials, and both sides must be essentially covered at the same time (tricky) ... then dried evenly , or warps could possibly still happen . This is not a problem on the “assembled" structure, which when shrunk , the skin material compresses the foam slightly making the structure stronger and tighter... which is always a “Good Thing “ !!!
Eagle , Maybe roughing up the surface to give it some “tooth” might help ... a good many finish and repair jobs are preceded by much Sanding and surface preparation (de greasing) .. Then at least you have a rough , clean surface for attachments.
