Bogo , re: your lifting airfoil trailer ... Yes it will lift a little , unless you’re going 100mph..
This has been mentioned elsewhere as well, but I don't see how a foil shaped trailer could possible generate ANY lift with a tow vehicle parked in front of it. Were we talking about vehicle bodies, it might be different, but the nose of the trailer (that splits and establishes the laminar flow) is operating in comparatively still air. Lift is directly proportional to airspeed.
Things get a bit weird when you get to transonic speeds but I try not to drive that fast, personally
Here's a good example: the Shuttle Carrier.
If you look at the side view, the tail nozzles of the Orbiter create a huge void in the flow that puts the Carrier's empennage in a pocket of still air (not to mention the drag it adds)
By fairing it with a tailcone the airflow converges again, though not completely as evidenced by the need for additional surface area outside the Orbiter's cross section (front view)
If we apply this idea to vehicles, it's why dogs stick their heads out past the outside of the pickup to get their noses into the airflow yet in the back of the truck they don't get blown around at all. It's also why a tonneau, canopy or mesh tailgate can improve fuel economy.
For this application, the ideal aerodynamic shape isn't a foil - it starts with the same cross sectional shape (adjusted for size as a function of the size of the gap and the design speed) of the rear of the tow vehicle. The taper of the tail does more for the aerodynamics of these trailers than the nose but rather than generating lift they would do the opposite by trying to keep the trailer within the flow coming off the vehicle. At least, that's the thinking that went into coming up with the nose shape for mine.
The horizontal top of the front panel is about the same height as the cab of the truck. While not a 'canopy', I have wooden sides on the truck to keep the dogs in and a transport tarp to go over top when needed to protect them from the weather. That will be how I tow it so that's what I built to.
Not being argumentative, just kicking the idea around.
