by Wobbly Wheels » Sat Jan 26, 2013 11:09 am
I tried some PL300 when I made up my SIP floor - I've found a latex contact cement so I'll be using that in the future instead.
First, it needs to warm - unless it's room temperature or better, the bead won't stick. That doesn't matter so much if you're gluing on the flat (like a floor) but it's a mess if you're doing anything vertical.
PL goes down as a bead, whereas contact uses 100% surface area for gluing. I wanted the bond spread out over the whole panel rather than at the bead.
I tried warming the tube and then spreading it with a notched trowel, but it's a bit too sticky to trowel well. Perhaps if one were to thin it a little ?
And yeah, it took a long time to cure and, even after a week, it was still rubbery (granted, conditions were much less than ideal)
FWIW, I'd use it to tack foam in place if working indoors except that it still needs the time to cure...
IMHO there are better options than PL300, given how we're using the foam.
Spray foam and GG both require an even clamping force (concrete pavers). Slightly thickened epoxy works great but $$$.
Others have had success with 3M 30NF (latex contact cement). I haven't tried Gripper so I don't know about that, but it certainly looks promising.
The contact I bought (30NF not available here) was about $40 for 1.5 l (a quart and a half) at a small-town hardware store.
