Postby eaglesdare » Thu Mar 24, 2011 4:50 pm
steve smoot wrote:Eaglesdare, pictures :thinking:
pictures of what?
Louella
May the foam be with you.
eaglesdare
Postby GPW » Thu Mar 24, 2011 5:39 pm
I think Steve wants pics of the artsy part ... Lots of potential there even with simple designs... Your imagination is the only limit ...
:thinking:
Postby eaglesdare » Thu Mar 24, 2011 5:54 pm
oh i'm sorry, but i don't have any pictures, sketches or anything. that part will just be a work in progress. won't be doing any painting for a little bit.
Louella
eaglesdare
Another super low cost frame idea
Postby Blotto Bros » Thu Mar 24, 2011 8:04 pm
While thinking about this thread today it seems to me the main goals here are: Easy, low cost and light weight building options.
I have a bunch of 3/4" schedule 40 PVC in my garage and realised that it would make a fairly rigid frame for the walls of a teardrop.(in place of wood)..could also work well for joining the spars to the walls and possibly door and window frames.
This idea would also fall into the "no rot or rust" column. Just a thought.
Even those souls that are found must occasionally become lost to appreciate what they have.
Blotto Bros
Images: 51
Postby GPW » Fri Mar 25, 2011 6:05 am
Quote: " it seems to me the main goals here are: Easy, low cost and light weight building options. "
Yep, that's it !!!
But I don't know if sch. 40 is strong enough .... maybe ??? Sch 80 may be better ... but you don't have that , so there goes the budget ... :o
Eagle , you may consider a couple quick sketches before you paint ... that always helps me sort things out before I touch a brush ... ;)
Postby eaglesdare » Fri Mar 25, 2011 8:36 am
oh my gosh, its freezing again ! more rain, and the mention of snow also. i wantm no i need warm weather!!!!!!!! time is running out.
Louella
eaglesdare
Postby GPW » Fri Mar 25, 2011 9:10 am
in the words of RRD, " just goes to show, it's always something !!!" :lol:
You have rotten weather , we have Nice weather , and I have no place to build ... :cry: ... Yet ! Working on that now !!!
Postby eaglesdare » Fri Mar 25, 2011 9:30 am
we did the shell building out in the ponies run-in. we put them out in the back pasture.
so my shell is now right outside my back door. poor thing just sitting there covered in tarp. but on the plus side, "IT IS" sitting there. it has not blown away yet. everything else has blown over to the neighbors. but the tear is still here. :lol:
i am having a couple of tearjerker gals come down the 1st weekend of april to finish the doors and canvas it. so far [always subject to chance] the weather is looking ok for that saturday. so we might have to move it back to the run-in.
that weekends plans are doors, canvas, and latches. at that point it should be campable. everything else will happen as time and money and weather allows.
i know i am a bit paranoid, i am thinking of getting some long straps to go over the top of the tear for traveling, holding it onto the frame. i am sure it is not necessary, but i might do it anyway.
Louella
eaglesdare
Postby eaglesdare » Fri Mar 25, 2011 9:39 am
can you smell the smoke your way gpw? i have been thinking about that roof foam that was scored for the bend.
should i fill that in? or will just the canvas do fine?
Louella
eaglesdare
Postby GPW » Fri Mar 25, 2011 12:03 pm
I was wondering what you were going to do with the kerfing slots ... but fabric "should" bridge it OK ... Might be a pain filling them in with lightweight spackle ... :roll:
If the floor is bolted down and you've put the reinforcing strips down the sides/edges ,inside and out you should have no problems @ <150mph ;)
Postby Miriam C. » Fri Mar 25, 2011 12:41 pm
eaglesdare wrote:can you smell the smoke your way gpw? i have been thinking about that roof foam that was scored for the bend.
I kerfed the curved framing on my Td and put PL expanding glue on before clamping it in place. I don't advise this glue because I could still smell it months later.. :roll: You might put some limited expansion/or no expansion foam in it to "glue" it together...If you can get to it :thinking:
Postby GPW » Sat Mar 26, 2011 5:03 am
Auntie , thinking the best alternative to the PU glue would be Epoxy glue ...that has a little smell but quickly goes away ... Most of the solvent based glues will melt the foam ... :o
Unfortunately , the T2 won't dry on the foam (no way to evaporate) .. that would be nice if it did ... There'a always Hot glue , but it's tricky to use on such big surfaces... but it might be good for "spot welding" the foam , while the glue dries (or expands) ... :thinking:
Perhaps the covering over the foam would seal the smell out (or in) ...???
Postby eaglesdare » Sat Mar 26, 2011 1:54 pm
how about something like this on painted on the side.
Louella
eaglesdare
Postby GPW » Sat Mar 26, 2011 3:45 pm
Oh Yeah !!! That would be really COOL ... Easy to do Bold like that ! 8) 8) 8)
Postby eaglesdare » Sat Mar 26, 2011 3:50 pm
well it was easy to do it in photoshop elements, but i am not sure about real life paint!
but i am thinking about something on this line.
but if i kept it rough, it would not have to be perfect.
Louella
eaglesdare
