GPW wrote:...if you take the time to make every part fit perfectly (like KC does
ROFLMAO
GPW wrote:...then you don’t need a gap filling glue
Thanks for the great, tho slightly delusional complement, Geep-dub.
If only it were true! I spend the time where I need to, and try to do good everywhere else, but there have been many times where I have relied on the GG to (sometimes) fill in slight gaps. It doesn't always kick as hard as you might want it to (sometimes leaving small void areas... at least when the climate has been dry) so it is still better to have a good fit over most of non-critical joints. Where I did not get full extrusion or had some void areas I just didn't worry about it too much because I figure 90/ct of the part in question was solid and, if you plan it well, the strength comes from the sum of the structure.
By restricting the expansion (tight fit and good clamping and/or weight) the bubbles in the GG foam stay tight and close together, providing much more structure to the joint. If you have some gaps, lay it on a little thicker and really give it a good spritz of water, it will really kick and expand out, but each bubble will be bigger and there will be less structure in the joint.
More smaller cell walls closer together = stronger joint.
Fewer cell walls farther apart = weaker joint.
For larger jobs that need a true filling foam I would probably suggest Great-shh-stuff. I haven't found a need for it yet, but may fill some of the gaps in my foam filler panels in my doors and bulkhead wall.
