Here we go:
Charlie was at work when I glued this on. It went on pretty smoothly but as you can see it has a nasty warp in it.
I needed to glue a board on anyway that the bed will attach to from the inside. This, I am hoping will hold that back end down when we are going down the road. So here I have the board glued in place and supported with lots of other boards and clamps and wedges.
When I remove all that, the bow in the styro was stronger than the glue and both ends of the board popped off leaving me with a half glued board and a still bowed back end. Soooooo.....you guessed it. I took the whole thing off and started over with some help from hubby.
In this picture you can see the finished back end. We glued the board on 1st and reattached it. I don't think I could have done it by myself because of the strength it took to tighten the straps. Even with Charlie doing the straps it still had a tiny bit of bow in it but we quickly cut some boards and wedged it against a nearby table until it was dry.
We had a few friends drop by to supervise.
I thought I took pictures of it after we took the straps off but I guess I didn't. We are headed out of town to a rat convention for the weekend, so I will get some more pics of it when I get back. It really turned out nicely. Now I need to clean up some of those seams and then I can put the skin on.
The other thing is that I am thinking about ordering some marine dock bumper to trim out the edegs. I think that will kind of hide the seems and give it a more finished look.
