Types of foam
Types of foam
Postby Staypuff68 » Sat Jul 09, 2011 9:17 am
The good news I was able to latch on to some 3" 4x8 sheets of styrofoam. The bad news is it is the white bead type, not the blue or pink. I am working up the nerve to start my pop up project and I was wondering if anybody has used this stuff. I am testing it with a a spot of TB, carpenters glue and latix paint left over from painting my girls room.
Staypuff68
Postby GPW » Sat Jul 09, 2011 11:17 am
SP, We've built and flown (RC) many a successful foam wing out of the beaded board ... and you have the Thicker 3" which should be fine with a little wood bracing in stressed areas (as per usual) ... The T2 and similar glues will stick well to the beaded foam ... but Gorilla Glue would probably be best for joining panels ... You've probably seen all the tricks everybody uses to join it and add framing , etc. all very useful ...
It's like the old saying , if it doesn't look strong enough , use more foam ... make it thicker ... You'll appreciate the insulation factor too ... :thumbsup:
Beaded foam might just be the Thrifty Alternative we've been seeking ... ??? :thinking:
Postby eaglesdare » Sun Jul 10, 2011 5:28 pm
can't wait to hear what you have to say about the white bead foam. good luck. i would think with it being 3" it should work well. but don't take my word for it, i haven't used it.
Louella
May the foam be with you.
eaglesdare
Postby GPW » Sun Jul 10, 2011 5:54 pm
Eagle , did you catch this statement??? "Beaded foam might just be the Thrifty Alternative we've been seeking ... ??? " .... crumbs for thought ... :thinking: Much cheaper than the Blue/pink/green, readily available in many sizes and densities... :o
Test spots
Postby Staypuff68 » Sun Jul 10, 2011 8:35 pm
After two days of drying the test spots all look good. The elmers carpenters glue, the tight bond II and the interior latex all dryed with out breaking up beads in the panels.
I am thinking that I will make a frame for the panels out of 1/2 OSB ($3.00 a for a 4X8 sheet at the habitat for humanity restore) and then cover the whole thing with the vinal wall paper I got at the same place. I use the wall paper to cover the floor of my kids tree-house (glued down with latex house paint) and it held up all thru the winter. So far I am in for $140, including the trailer.
Staypuff68
Postby GPW » Mon Jul 11, 2011 8:16 am
SP, I believe that will work !!! :thumbsup: Can't beat the price !!! less than a tent ... :o 8)
Postby eaglesdare » Mon Jul 11, 2011 9:13 am
good job! remember NOT to forget those pics, step by step.
Louella
eaglesdare
Good news and Bad news
Postby Staypuff68 » Sun Jul 24, 2011 9:02 am
The bad news is that I probably won't be building a foamie. The good news is the reason i won't be building a foam is because I just picked up a 1973 Sprite Musketeer for $200 off of CL. The more bad news is that it is full, and I do mean full- like open the door and they fall out, of vintage beer cans. The more good news is that I can probably sell the cans to a collector or for scrap and pay for the trailer. Looking forward to the project. Now if I could just find another one for parts.......
Staypuff68
Postby GPW » Sun Jul 24, 2011 9:59 am
We'll need some pictures of that for sure ... SP :D
450 cases of empty beer cans
Postby Staypuff68 » Fri Aug 12, 2011 8:02 am
This is what was in the Sprite. For referene my son is around 5 foot.
Staypuff68
Postby GPW » Fri Aug 12, 2011 8:18 am
Gee whiz !!! I wonder if that's what 500 lbs. of Beer looks like .... :o That's a Lot of cans SP !!!! 8)
Postby CARS » Fri Aug 12, 2011 8:57 am
Sorta looks like our campsite after a week.... :?
You should be able to pay for the trailer by just recycling!
Chris'
Autobody
Restoration
Service
CARS
Postby eaglesdare » Fri Aug 12, 2011 8:58 am
GPW wrote:Gee whiz !!! I wonder if that's what 500 lbs. of Beer looks like .... :o That's a Lot of cans SP !!!! 8)
:lol:
Louella
eaglesdare
Postby GPW » Fri Aug 12, 2011 10:53 am
Somebody had a "Lost Weekend" ! ... :o 8) :lol:
