Interesting reading about foam core panels.
Postby loaderman » Fri Feb 17, 2012 1:44 am
"It is estimated that by increasing the sandwich thickness by two, the panel will become 12 times as stiff and six times as strong. The advantage of a sandwich is that little weight is added when increasing the thickness." http://www.sandwichpanels.org/articles/article_sandwichoanelcores.html
"Based on my spreadsheet, a 4’x8’ panel comprised of a ½” BC plywood (5-ply) top and bottom lid and a 2” extruded polystyrene core (i.e., pink or blue rigid foam insulation board) can carry a load of 41 pounds per square foot,"
http://theatreface.ning.com/profiles/blog/show?id=2529492%3ABlogPost%3A147917&commentId=2529492%3AComment%3A148435&xg_source=activity
loaderman
Re: Interesting reading abuot foam core panels.
Postby GPW » Fri Feb 17, 2012 6:53 am
We’ve been saying all along , when in doubt make the foam thicker ... :roll:
Re: Interesting reading about foam core panels.
Postby pete42 » Fri Feb 17, 2012 7:46 am
Interesting confirmation to what Glenn has been saying. :thumbsup:
Double the thickness six times as strong........let's see; at 16 I was this thick, at 70 I'm now this thick................hummmm
nope I don't feel six times as strong must not work in all cases. :o
oh well........lets have another beer........... :beer:
pete42
Postby eaglesdare » Fri Feb 17, 2012 8:31 am
how about wine instead of beer :wine:
Louella
May the foam be with you.
eaglesdare
Postby GPW » Fri Feb 17, 2012 8:46 am
Think about it ... how secure would feel with a 4” thick wall , or a 6” thick wall ? ... :thinking: As L' has confirmed . thicker IS stronger , and my Little foamie is stronger because the 2” material is “relatively” thicker than it would be on a larger Foamie ... Does that make sense ? Think of the Insulation factor of a thicker material too ... :thinking: Foam is still the lightest part of the equation , so you can use a LOT of it without much weight penalty ... :thumbsup:
Postby GPW » Fri Feb 17, 2012 10:03 am
For those that would feel even more secure with a thicker skin , but prefer the ease of using canvas for the panel skin ... we have seen and painted on some extremely Heavy (thick) canvas in the past .. Incredibly Strong , a Bit heavier too ... obviously more expensive ... but if you want strength .. :roll: It’s out there... just have to look around the industrial sites ... Ever see a canvas fire hose ... TOUGH stuff ... !
Postby loaderman » Fri Feb 17, 2012 4:36 pm
Yep, makes sense, just real good to have numbers to back it up.
loaderman
Postby atahoekid » Mon Feb 20, 2012 1:24 am
Facts like these might even convince the naysayers. I never thought of it as a core panel when I started my build but when you stop, step back and take a look, that's exactly what we're building. If I had thought about it as core panels originally, I might have gone about my build a bit differently. Vacuum bagging even starts making sense...
Mel
atahoekid
Images: 158
Postby GPW » Mon Feb 20, 2012 6:58 am
QUOTE: “ Facts like these might even convince the naysayers. “ .... Not likely ... unless they’ve actually Built one ... :roll:
Postby atahoekid » Mon Feb 20, 2012 12:02 pm
Sorry, the optimist in me got carried away.... 8) :lol: 8) :lol:
Mel
atahoekid
Images: 158
Postby angib » Mon Feb 20, 2012 1:16 pm
loaderman wrote:"Based on my spreadsheet, a 4’x8’ panel comprised of a ½” BC plywood (5-ply) top and bottom lid and a 2” extruded polystyrene core (i.e., pink or blue rigid foam insulation board) can carry a load of 41 pounds per square foot,"
Two half-inch ply skins on 2" foam core is hardly lightweight material is it? And I wonder if the guy has actually done all the stress calcs and not just the bending one - I would expect the insulation foam to fail in shear long before the ply skins failed. Real foam-core structures are made with structural foam that is slightly less expensive than gold, but only slightly.
We don;t seem to be seeing forum members posting a flood of finished foam teardrops, which may be because it's easy to start a foamie but not so easy to finish it?
angib
5000 Club
5000 Club
Images: 231
Postby GPW » Mon Feb 20, 2012 4:02 pm
See what I mean !!! :roll: Guess they told the Wright Bros. that too ... we know how that turned out ... ;)
Postby linuxmanxxx » Mon Feb 20, 2012 6:38 pm
With the display of how simple paper and elmer's glue can more than triple the load on the foam, why does everyone get their head wrapped around using heavy materials on the skin such as 1/4 plywood? I've used 1/8" luan on all mine and can walk on it at almost 200 pounds so I'm just confused why people keep using 1/4 and 1/2 in their torsion box builds.
linuxmanxxx
Images: 10
Postby eamarquardt » Mon Feb 20, 2012 7:12 pm
As it has been explained to me an "I" beam gets stronger proportional to the Cube (3rd power) of the distance between the horizontal elements. So a beam 2" high is 8 times stronger than a beam 1" high.
Here's the formula (but it's in "Greek") Image
In reality I think the foam/skin bond would break down prior to reaching this predicted strength but it supports the notion espoused earlier.
I'm not sure why the formula won't show but it's in my album: gallery/image_page.php?album_id=1588&image_id=87997
Gus
eamarquardt
Images: 150
Postby loaderman » Mon Feb 20, 2012 9:34 pm
the link says I am not authorized. :cry:
loaderman
