Though the idea of a fiberglass tub in the trailer has a lot of appeal I still have strong reservations about trying it. Skinning the trailer with canvas sounds doable. Trying to work with fiberglass just sounds so much more intimidating. Cost seems rather high also, especially with dubious results. Its hard to feel enthusiastic about attempting that. Fear of the unknown, I guess.
GPW, carpet remnants are cheap & easy enough to acquire but we'd be dealing with dirty and likely often damp/wet carpet. Doesn't sound like fun trying to get it dry again & clean enough to prevent odors. We'll have enough odors when the dogs are along.
Am I just being too pessimistic?
swampjeep, I had thought about vinyl. A solid sheet folded up at the walls, tub like, avoids the problem of seams except at corners. We could try it but am doubtful it would prove durable enough on it's own. Something else to serve as a removable liner might make it more functional.
Did a little reading on the FRP previously. Someone had mentioned using it to skin the interior walls, at least up to a certain height. For that purpose the cheap 4'x8'x1/8" sheets seemed somewhat affordable. Could I use that for flooring or some other type? Could I seal the seams with glue or silicone caulk or would I also need to use the molding used for shower walls? And the mention of itchiness. Ugh! I've got snips I could use for smaller cuts. Could I use our little, cordless, Dewalt circular (trim?) saw for larger cuts? It's got an approx 6.5" blade. Maybe I could use one of these blades?
Abrasive masonry blade # DW3509
http://www.homedepot.com/p/t/203150189 OSB/plywood blade
http://www.homedepot.com/p/t/202035216*edited* I used to be handy with a jigsaw. Dad's still got his that he never uses. Could steal... er, borrow it.
Many thanks for all the ideas!
Laura
