Warren , covering does take a bit of practice , and it always gets better as you go along ... Just
take your time and do a lot of pulling stretching , smoothing till it’s on real nice and tight (we’ve been using blow gun darts for tacks ) ... then keep an eye on it as it dries so you can pat down any offending bubbles before it sets up ... otherwise , the warm iron trick works after it’s dry .... I don’t know why everyone’s reluctant to try that ... all it does is cause the adhesive to go thermoplastic and re-stick itself ... (if you’re using the good household Iron
, a towel underneath will help keep it clean , and protect the foam and finish ! ) Naturally too hot an iron will melt the foam
Test on scraps as always , or if you have a thermometer , set it for ~ 160F , that’s good for a start and won’t melt the foam.. Try not to go above 190F .. take your time , and those bubbles will disappear Forever.. Ps. if it’s a big bubble you may punch a small hole in the middle of it to let the heated vapors to escape .. otherwise as you heat the trapped air inside , it just expands and makes the bubble BIGGER ...
This also works for flattening seams too ...
What sticks up , gets ironed down ...
