40" wide, about 7' long, and maybe 5' tall when extended
WizardOfOdds wrote:40" wide, about 7' long, and maybe 5' tall when extended
hummm. What is the maximum folded height you can tolerate? .
angib wrote:... and you run the risk of making your foamy a woody.
ghcoe wrote:It can be done. Not sure how their pop up system works, but it might give you some thoughts....
http://www.goldbrand.info/motorcykelhusvagn2.html
James06 wrote:ghcoe wrote:It can be done. Not sure how their pop up system works, but it might give you some thoughts....
Thanks, that is exactly the type of concept I was thinking about. I don't really need 10 feet long, but everything else looks pretty good. I winder if the canvas/ foam route would be as sturdy as their fiberglass/foam design?
