Attaching your foamie to the trailer?
Postby steveonzakon » Mon Sep 01, 2014 6:07 pm
I've been pouring through the foamie thread for quite some time and I think I understand that the only places you might need framing is around window, door and possibly vent cut outs. Also inserting hard points where you expect to attach things to your walls.
The one thing that is still eluding me is... how do I attach the foamie to the trailer? Are the walls glued and skinned to a plywood floor and the floor bolted to the trailer? If so I assume 5/8 or 3/4 plywood is what is needed.
I'm kind of stumped on this.
Campers are for sleeping in, almost everything else should happen outside.
steveonzakon
Re: Attaching your foamie to the trailer?
Postby lthomas987 » Mon Sep 01, 2014 7:02 pm
That is it. Glue down the foam with gorilla glue. My half inch OSB is actually screwed to a 2x4 frame. That is attached to the trailer. But only so I could go wider than my wheels.
Well almost entirely.
Most people have wrapped their canvas under the wood to hold the foam.
I am about to put 6" wide bias strips of linen on the joint. Before then putting the canvas over it.
Laura
lthomas987
Images: 204
Postby steveonzakon » Mon Sep 01, 2014 7:43 pm
2x4 frame under the plywood floor. Good idea, as I also want to go wider than the trailer frame, and was thinking of having a steel extensions welded onto the frame. This helps a lot and gives me more ideas. :twisted:
steveonzakon
Postby lthomas987 » Mon Sep 01, 2014 8:55 pm
You could look at the early parts of my build thread. Also there is another guy who I have been copying a lot from who had MUCH better pictures.
Laura
lthomas987
Images: 204
Postby atahoekid » Mon Sep 01, 2014 11:09 pm
I epoxied the walls to the 1/2" floor and then wrapped fiberglass down and around. About 6" up the wall and about 4" under the floor. You could do the same with some glue and canvas but I had already committed to fiberglass and epoxy
Mel
atahoekid
Images: 158
Postby jseyfert3 » Sat Sep 06, 2014 11:35 am
I used hurricane ties to attach a 1x4 frame to the trailer. This raised it up and allowed me to widen it. My trailer (in progress) is 5'6" wide on a 4' HF trailer. Inside is completely flat and fits a queen sized spring mattress. I have to get on my computer to get you the link to my build thread for pics though.
jseyfert3
Postby jseyfert3 » Sat Sep 06, 2014 11:44 am
Here you go. Attaching hurricane ties to the frame is here. Just below that post is how I fit 1x4's into the holders (they are made for 2x4s, I used 1x4s to save weight, they are plenty strong enough for this purpose). http://tnttt.com/viewtopic.php?f=50&t=58559#p1063803
Assembling my frame starts here: http://tnttt.com/viewtopic.php?f=50&t=5 ... 5#p1067775
Hopefully this helps you. :thumbsup:
jseyfert3
Postby steveonzakon » Sat Sep 06, 2014 11:58 pm
Thanks a bunch. My wife derailed me by strongly requesting I finish her greenhouse sitting area before I start any other projects, but I am copying all this information down in a master document to refer back to later.
steveonzakon
Postby Jst83 » Mon Sep 08, 2014 10:16 am
steveonzakon wrote:Thanks a bunch. My wife derailed me by strongly requesting I finish her greenhouse sitting area before I start any other projects.
:lol: Doesn't that sound familiar but my wifes upset that I've been working on a tree house for the boys instead of getting the door back on the camper.
And for input on your question mine is framed with PVC then foam fitted in the frame, the PVC is metal strapped to the floor.
http://www.tnttt.com/viewtopic.php?f=55&t=56828
Jst83
Images: 215
Postby lthomas987 » Mon Sep 08, 2014 11:15 am
lthomas987 wrote:You could look at the early parts of my build thread. Also there is another guy who I have been copying a lot from who had MUCH better pictures.
There is the one with the much better pictures!
http://www.tnttt.com/viewtopic.php?f=50&t=58559
Laura
lthomas987
Images: 204
