The HF 4x8 chassis.
The HF 4x8 chassis.
Postby mikeschn » Wed Feb 29, 2012 6:20 pm
Everyone should start with a chassis. And here's a popular one! The HF 4x8 chassis.
4x8_hf_trailer.skp
(5.86 MiB) Downloaded 1330 times
Re: The HF 4x8 chassis.
Postby mikeschn » Wed Feb 29, 2012 6:33 pm
Since this file was exported from a different cad system, I need you guys to tell me if it's usable.
Postby SteveW » Wed Feb 29, 2012 7:54 pm
What a great idea. Thanks for posting this. This will make a good resource.
The build is on.
SteveW
Postby parnold » Wed Feb 29, 2012 10:00 pm
Mike:
I opened with Sketchup 8 and the measurements were way off. More than twice the size it should be. 202" long instead of 96", and 100 inches wide instead of 48" (measuring the frame).
parnold
Images: 302
Postby danlott » Thu Mar 01, 2012 12:59 am
Here is a Harbor Freight trailer that was in the Google SketchUp warehouse. I reworked it a little bit and cleaned it up.
harbor freight trailer.skp
Harbor freight trailer
(441.95 KiB) Downloaded 651 times
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Postby pohukai » Thu Mar 01, 2012 10:32 am
danlott wrote:Here is a Harbor Freight trailer that was in the Google SketchUp warehouse. I reworked it a little bit and cleaned it up.
Dan
I had used this one as the base, but the distance of the axle to frame is off about 2" from the real thing. Mine is closer to 4 3/8".
JimG
pohukai
Images: 9
Postby mikeschn » Thu Mar 01, 2012 11:58 am
parnold wrote:Mike:
Sounds like the scale factor is 2.12? You might try scaling it down by a factor of .4717
Postby TheDuke » Thu Mar 01, 2012 8:58 pm
Most of the things I brought in from the Warehouse had scale problems. Some were 1/12, some were not. I had to import it to my drawing first, then measure it, and figure out the scale factor, then scale it up or down by that number. A real pain, but I couldn't have done some things without it.
It's just the cost of doing business.
TheDuke
Images: 68
Postby markhusbands » Tue Jul 10, 2012 6:19 am
Anyone have the HF model in an older version of Sketch-up?
I have 6.something and cannot seem to get my computer to install 8.0....irritating.
The model would be a huge help.
Thanks, Mark
133923
markhusbands
Images: 58
Postby TheDuke » Tue Jul 10, 2012 10:16 am
Strange that you can't load 8.0. You must have an older version of XP. I'd send you mine, but it's in 8.0 and includes all the specific tweaks that make it work for my trailer. BTW, did you notice that SketchUp is not Google anymore?
TheDuke
Images: 68
Postby markhusbands » Tue Jul 10, 2012 4:30 pm
Yep, Trimble now. And yeah, I can't figure out the download problem - I just get an irritating error message that makes no sense to me. And I don't think my XP is THAT old. But anyway, can't do it...
133923
markhusbands
Images: 58
Postby TheDuke » Tue Jul 10, 2012 6:57 pm
Just a thought: I have run other browsers for awhile, not IE. So I had "automatic update" turned off, because it interfered with things. As a result, I had never received Service Pack 3, and MS isn't automatically supporting XP anymore, so I had no idea. So I got online and found a place to download it from, and a number of little nagging problems went away. Maybe that's what you need to do. Worth a try.
TheDuke
Images: 68
Return to Sketch up designs
