Plywood thickness
Plywood thickness
Postby Irving » Wed Mar 13, 2013 4:43 pm
What thickness of plywood have you used for the interior as well as exterior walls of your build? If you have insulated - what thickness insulation foam board have you used?
After exploring the idea of a "foamie" build I am blown away that you can build almost the whole thing out of foam board and have it be structurally sound.
I am considering the idea of using just 7/32" plywood for both the interior and exterior walls and putting 1.5" foam insulation in the middle. This is a huge departure from my original plan of using 1/2" plywood on the interior and exterior.
Irving
Re: Plywood thickness
Postby Woodbutcher » Wed Mar 13, 2013 7:29 pm
The one trailer I built that was completely insulated I used 1" foam between 2 , 1/4" sides. There was a stick built frame as well. Not a foamie.
Woodbutcher
Postby Irving » Wed Mar 13, 2013 7:47 pm
Woodbutcher wrote:The one trailer I built that was completely insulated I used 1" foam between 2 , 1/4" sides. There was a stick built frame as well. Not a foamie.
What do you mean by "stick built frame"?
Irving
Postby OuttaHand » Wed Mar 13, 2013 8:36 pm
Mine is 3/4" exterior ply, 3/4" foam insulation, with 1/4" plywood on the interior.
Teardrop newbie but camping "oldster"
OuttaHand
Postby Woodbutcher » Wed Mar 13, 2013 8:38 pm
Woodbutcher
Postby Gage » Wed Mar 13, 2013 10:35 pm
I build my teardrops with 1/2" outside ply (main wall), 3/4" foam then 1/8" inside ply. That's what works for me ;)
Image Image Image
Gage
Images: 28
Postby Bigblock352 » Thu Mar 14, 2013 7:52 am
I'm using 1/2 ply with cut outs with 1/2 foam in the cut outs for the main wall with 5 mil outside and 1/8 inside.
Bigblock352
Images: 39
Postby Vindi_andy » Thu Mar 14, 2013 12:01 pm
Mine is similar to woodbutchers 1/4" in and out with 1" insulation between and simple stick frame. Had even less sticks then wood butcthers. 1 either side of door and window running top to bottm and one where the galley bulkhead will be. Just enough to join the 2 faces together. Still pretty heavy things.
Boys never grow in to men the toys just get more expensive and more dangerous
How true :)
Vindi_andy
Images: 49
Postby dwgriff1 » Thu Mar 14, 2013 4:03 pm
1/8 almost everywhere.
dwgriff1
Postby Irving » Sat Mar 23, 2013 5:02 pm
So I am building my walls with 1.5" foam insulation and 1/8" hard fiberboard on the inside and most likely 1/4" OSB (chip board) on the outside. I am going to be covering the entire outside and bottom with canvas and tightbond 3.
I'm still a bit hung up on using the OSB board. I almost bought a bunch of 11/32" plywood but decided it was too heavy and put it back.
Should I be talked out of using 1/4" OSB board? Any good reasons not to use it? It is just so cheap at $9.50 for a 4x8 sheet and it's quite lightweight. I'm having a tough time finding inexpensive 1/4" plywood in my area.
Irving
Postby 48Rob » Sat Mar 23, 2013 5:43 pm
Though some have used OSB, it is a poor choice as it will break down very quickly if moisture finds a way in.
If it will be completely encapsulated, it might hold up, but it is quite a risk to take.
In my opinion, 1/4" OSB is not anywhere near as strong as 1/4" plywood.
Rob
48Rob
Postby Irving » Sat Mar 23, 2013 7:25 pm
Rob
Not the answer I wanted to hear. haha Yes, it is going to be very encapsulated. The roof, walls and underbody are going to be covered in canvas that is sandwiched between layers of waterproof tightbond 3. Then primer and paint.
Irving
Postby Kody » Sun Mar 24, 2013 1:12 am
My TD will be built using 1/2" ply for the sides, no insulation. The bulkheads will be 1/2" ply, the galley will be 1/2" ply and the ceiling and roof will be 4mm. All glue for woodwork will be Titebond 3.
Kody
Never be afraid to ask questions here, Prov. 11:14
Kody
Images: 22
Postby 48Rob » Sun Mar 24, 2013 8:35 am
Hi Irving,
I may be misunderstanding your explanation/plans??
If the glue and canvas will be on both sides of the OSB, and also cover all sides and ends, you might be okay
If the glue and canvas is just on the exterior, the OSB will still absorb moisture.
If you try it, be sure to pay extreme attention to anyplace your complete seal is broken, such as window openings, vents, and especially screws or other fastener penetrations.
I'm a fan of installing fasteners, then removing a few at a time and injecting sealer in the holes before replacing them, to seal both the head and threads of the screw, and the raw material exposed by placing the hole/screw.
Rob
48Rob
Postby Irving » Sun Mar 24, 2013 2:41 pm
Ended up picking up 5.5mm (7/32") plywood for the exterior.
http://www.homedepot.com/p/5-5-mm-7-32-4-ft-x-8-ft-Underlayment-431178/203183022#.UU9WuDeyItY
It feels quite hard and sturdy for as thin as it is..
Irving
